on
2022-09-29
10:54 AM
- edited on
2022-10-11
11:48 AM
by
Noemi Balogh
This article aims to provide some insight into our 2D modernization project spanning across multiple Archicad versions. The focus will be on the changes in line rendering and its benefits.
As the title implies, the material is recommended for readers interested in the inner workings of the software to gain a better understanding of why it changed as it did over the years.
Before I dive into the details, a short summary of the technical terms used:
While Archicad itself is cross-platform, the underlying source code that handles rendering wasn't for a very long time. Early attempts were made in Archicad 22 with the introduction of an extensible software interface backed by OpenGL 3.3. I'm going to refer to this as (Archicad's) GPU interface.
During the development of Archicad 25 we started a modernization project (first on macOS), which had two goals:
Another argument supporting the latter was the numerous driver crashes caused by the then current anti-aliasing solution (MSAA).
The next milestone of this modernization (with Archicad 26 as target) was to renew our hybrid Direct3D-OpenGL drawing infrastructure on Windows (I'm going to refer to it as legacy implementation). Here we had additional concerns:
The decision we made was to get rid of the legacy implementation, and reimplement the Direct3D functionality under the platform-independent GPU interface. This effectively means that starting with Archicad 26 we have a truly cross-platform implementation which we can improve without dealing with the rendering API differences.
Without the gobbledygook, the anti-aliasing part is just a Gaussian function (so-called bell curve) perpendicular to the line's direction. Note that I'm using the word "line", while in fact they are rectangular polygons. From left to right: aliased, MSAA, shader-based rendering
The strength of the algorithm is that it can render round caps (in fact any type of cap) for free. In the legacy implementation caps were done by calculating the actual geometry, which meant unnecessary memory usage and segmented look at high zoom levels.The legacy implementation (left) had to manually generate rounded caps, whilst the new one (right) calculates them during rasterization
It also saves the memory that would come directly from MSAA (i.e. the driver doesn't have to allocate memory for subpixel samples).
The new Direct3D implementation automatically detects the stronger GPU on multi-GPU systems. If desired, this feature can be turned off by setting the following registry key to zero:
HKCU\SOFTWARE\Graphisoft\Archicad\Archicad XXXX\Graphix\AutoDetectGPU
This is recommended for laptop users when the device cannot be connected to the power outlet for long periods of time. Note that Windows' Power saving setting might not have an effect on its own.
Generally it is not advised to touch the registry. Should you be unsure, contact your local technical support for a step-by-step guide.
