Update Archicad 28 Keynote Tag
Emilio
Is there a way to update a keynote label with a different tag without placing a new label? In CI Tools you were able to just click on a new tag and remove the old one. Is that possible with the new native keynote tool? In the image below, say I wanted to update the keynote to 02.03 instead of 02.01. Thanks!
James B
Hi thanks for the feedback.
We are working on an improvement, planned for the AC28.1 update, to allow replacing a selected labels content with another key. Currently, you can double click inside the label text to edit the content directly, to place another keynote.
James Badcock
Graphisoft Senior Product Manager
James B
James Badcock
James,
Thanks for the info, I'll keep an eye out for this in the update!
Zendrix
yes, this is so basic and crutial i cant understand how it is not built-in. having to place a new label just because you decided to change your material is a pain no one deserves. 🙂
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
Setup info provided by author
