Vertical Marker Text
We are trying to finish up a set of documents, and we have used the simple detail marker. All of the markers that are horizontal come into plotmaker correctly, but with the vertical markers, the text is way above the marker. Is this a known bug, and is there a simple, quick solution? It would be great to get this fixed today and do our final plots. Otherwise, I am going to have to resort to using dumb text to key the details. Attached is the plotmaker screen.
5 REPLIES 5
And this is the Archicad Screen.
Link
Millard,
I had a similar problem, and I simply changed the marker to something else, then changed it back and if fixed the problem.
Also cre-heck the text settings of the marker. Maybe you have some unwanted spaces in your custom text or something. A long shot, but it may be the case.
Link.
Link.
No custom text, trying to keep the plotmaker text so I get a auto reference.
This may be a bug. Only tested it with the marker you used (no others). If the marker is rotated more than 90 degrees, the text jumps.
Woody
Sorry.. corrected picture below
