2014-09-17 04:19 PM - last edited on 2023-05-19 03:56 PM by Gordana Radonic
2014-09-17 04:52 PM
JAY wrote:Your image didn't upload.
This image shows my desired label but with manually edited text.
2014-09-18 04:30 AM
2014-09-18 06:30 PM
2014-09-19 01:26 AM
laszlonagy wrote:
This can be done because Labels can be scripted to obtain the Surface assigned to Walls.
There is actually an example of this in a webinar video:
https://www.youtube.com/watch?v=zV7c24vsOPM
At 32:50 he is opening and Elevation in which Surfaces of walls are displayed in a custom Label they created. At around 33:12 he specifically mentions that the Label is calling the surface of the element.
2014-09-19 01:26 PM
2014-09-19 03:08 PM
2014-09-19 03:24 PM
2014-09-25 04:04 PM
David wrote:
JAY TUX:
The Requests for the Surfaces are:
Request ("Name_of_material", WALL_MAT_A, Ref_Mat_Name)
Request ("Name_of_material", WALL_MAT_B, Other_Mat_Name)
Request ("Name_of_material", WALL_MAT_Edge, Edge_Mat_Name)
These return the 3 Surfaces of the Wall, which can then be used to script the Surface name as part of the Label. The 3 variables (Ref_Mat_Name, Other_Mat_Name, Edge_Mat_Name) can be any allowed variable name.
2014-09-25 04:15 PM
Nathan wrote:That would be great. If you/your guru could keep me posted that would be great. Thanks!
Gents,
I will get my GDL guru to give you some advice. A work around in ArchiCAD 18 would be to use IFC Mapping and the Generic Label listing the IFC Parameter. This way you don't need to know any GDL at all. I am in the middle of writing a new post on my blog about IFC Mapping that I plan to load up early next week along with a couple of YouTube videos to demonstrate how you can do it.
Good luck playing with it.
Regards
Nathan
