Wall Label That References Wall Surface
I was wondering if anyone knew where to get or how to customize a Wall Label so that i can have it displaying the Surface of that wall. These would mainly be used in elevation views where i want to document the claddings being used.
Currently i have labels with custom text which i edit and manually input the surface that it is pointing too. I have tried making a few with the some of the preloaded labels but couldn't get the desired outcome.
This image shows my desired label but with manually edited text.
46 REPLIES 46
Erika Epstein
Your image didn't upload.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Sorry, heres the image of what i was after.
This can be done because Labels can be scripted to obtain the Surface assigned to Walls.
There is actually an example of this in a webinar video:
https://www.youtube.com/watch?v=zV7c24vsOPM
At 32:50 he is opening and Elevation in which Surfaces of walls are displayed in a custom Label they created. At around 33:12 he specifically mentions that the Label is calling the surface of the element.
Thats exactly what i want to do. But in that tutorial he shows that it can be done, not how it can be done. I may be abit of a noob here but how do i script the labels to reference said data?
Unfortunately, I am not that familiar with the inner workings of Labels.
What I know is you will probably have to use the Wall's GDL Global Variables and/or some REQUEST function to obtain the surface value of the Wall.
Hopefully someone with more knowledge and experience on this part of GDL can chime in.
David Maudlin
JAY TUX:
The Requests for the Surfaces are:
Request ("Name_of_material", WALL_MAT_A, Ref_Mat_Name)
Request ("Name_of_material", WALL_MAT_B, Other_Mat_Name)
Request ("Name_of_material", WALL_MAT_Edge, Edge_Mat_Name)
These return the 3 Surfaces of the Wall, which can then be used to script the Surface name as part of the Label. The 3 variables (Ref_Mat_Name, Other_Mat_Name, Edge_Mat_Name) can be any allowed variable name.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Gents,
I will get my GDL guru to give you some advice. A work around in ArchiCAD 18 would be to use IFC Mapping and the Generic Label listing the IFC Parameter. This way you don't need to know any GDL at all. I am in the middle of writing a new post on my blog about IFC Mapping that I plan to load up early next week along with a couple of YouTube videos to demonstrate how you can do it.
Good luck playing with it.
Regards
Nathan
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC28 | WIN 11 | i9-10900K, 3.7Ghz | 32GB Ram | NVIDIA GeForce RTX
3070
David wrote:
JAY TUX:
David
Thanks David. As i have only made the move to Archicad earlier this year I am still a bit of a noob and have no knowledge of gdl script, or ifc mapping. So I'm still at a loss as to how to achieve this. Is this something i should be asking about in the gdl section of the forum???
Nathan wrote:
Gents,
Regards
Nathan
That would be great. If you/your guru could keep me posted that would be great. Thanks!
