3 weeks ago - last edited 2 weeks ago by Laszlo Nagy
Team:
I have an intriguing question.
Does anyone know what the Dark vs. Light Icon in the view map represents?
It doesn’t seem to be related to Dark Mode.
Please see the attachment for reference.
Solved! Go to Solution.
3 weeks ago
I’ve noticed this issue when switching back from Dark Mode to Regular Mode. Some icons can stay that way, but restarting Archicad usually fixes it. If that doesn't work try applying the built-in work environment and then restart your computer, this should do the trick.
3 weeks ago
Are you on Windows or MacOS? And which AC version are you using?
Maybe you can add this info to your forum signature. 🙂
My answer would be: It means nothing. It is just a glitch. I've seen similiar issues with other icons all around.
3 weeks ago
Runxel
3 weeks ago
