What is the Dark vs Light Icon in view map meaning
iggiv
Team:
I have an intriguing question.
Does anyone know what the Dark vs. Light Icon in the view map represents?
It doesn’t seem to be related to Dark Mode.
Please see the attachment for reference.
max_min
I’ve noticed this issue when switching back from Dark Mode to Regular Mode. Some icons can stay that way, but restarting Archicad usually fixes it. If that doesn't work try applying the built-in work environment and then restart your computer, this should do the trick.
MacOs Sequoia
Archicad 13 to 28
runxel
Legend
Are you on Windows or MacOS? And which AC version are you using?
Maybe you can add this info to your forum signature. 🙂
My answer would be: It means nothing. It is just a glitch. I've seen similiar issues with other icons all around.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Runxel
Thank you for your comments.
Computer information:
Computer mode: Mac Book Pro (16-inch, 2023)
OS: MasOS Sequoia 15.2
Software information: Name: ArchiCad
Version: 28.0.2 (3110) INT FULL
Hope this help. Thank you
max_min
MacOs Sequoia
Archicad 13 to 28
