Why is "wrap-text" still not fixed with keynote labels?
Kalib Stewart
This was brought up in the beta months ago and is STILL bugged.
Wrap text does not save for keynote labels. When keynotes have long descriptions, they remain one single absurdly long line and the wrap text deactivates by itself. We can't be dragging the frame inwards for every label every time, or selecting all and turning it back on again.
CI keynotes and even the standard labels save the frame width setting so we don't have to adjust every placed label repeatedly. Until this absolutely basic function is fixed, Central Innovation's keynotes will remain the clear default tool.
I would hope this is fixed soon, and is not the next Archicad 29 selling point that we're forking out ever-increasing thousands for.
Reg' Architect
I found that you made a post in the forums about this issue during the technology preview.  That is not a bug report and an ignored post is not an ignored issue.  If you did not enter it into the bug system, it has not been reported.  Please report via your local technical support, as even this thread is not a bug report but just a conversation to let fellow users know about your experience.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
4 REPLIES 4
When you make a post about an issue like this, please post your version (28) and build number so that everyone knows if you have the current hot fix installed.
During beta, did you get a defect number such as DEF-xxxxxx?  If so, please share it so that others for whom this issue is critical can contact their tech support who can readily add their voice to pressure for a fix.
Apologies - the version is the currently up-to-date one of 28.0.2 (3310).
There was no defect number issued - and like virtually all feedback on the keynote tool during the beta, it was ignored.
Reg' Architect
Kalib Stewart
Good to know; will do. Thank you.
Reg' Architect
Setup info provided by author
