Word document
What is the best way to get a work document into Plotmaker 3.1?
I have tried copy and paste. Does not really work.
It brings text in in odd groups of words but not really uses full.
is pdf and option?
Any Suggestions
ACAD 8.1
Mac OS X.3
G4 DP 1.25-1.25 MB-ATI 9800 Pro
11 REPLIES 11
MMontgomery
(I'm assuming 'work' document means Word)
Did you try importing the .doc file straight into PM?
It works well for me and when changes are made to the Word file it shows up in Plotmaker.
AC 6-29 - Ryzen9-9950X / 96GB RAM / RTX 5090 / Win 11 Pro
Importing Word documents does not work in OSX.
__archiben
unfortunately this isn't available as a feature on a mac at present - requires the OLE support only found on windows machines.
it would be nice to live-link word and excel files though, graphisoft?
~/archiben
b e n _ f r o s t
So how does everyone deal with this?
Do you just deal with the poor copy past technique?
MMontgomery
I'd suggest buying a Windows machine
muwahahahha
__archiben
what kind of information are you wanting to use in plotmaker?
b e n _ f r o s t
Its a multipage word document that i need to bring into a plotmaker layout.
Aussie John
Apparently Microsoft haven't released the appropiate details so in can't be incorporated into the Mac OSX
My work around is to create a PDF, then in preview export it as aPNG type file and place that into plotmaker.
The trick is to "up" the resolution and you do that by setting the size in your page setup to about 200%. it will import into plotmaker at 72 dpi so you can then shrink it to give a resolution of about 150 which prints fine.
Cheers John
[/size]
has anyone tried office 2004? I'm wondering if the OLE support exists yet. What version of OLE support does plotmaker have? According to Microsoft Mactopia page:
http://support.microsoft.com/default.aspx?scid=kb;en-us;122194
if plotmaker supports OLE version 2.0, it should work? has anybody tried 2004 yet?
