ā2023-11-23 02:32 AM
I have created a zone schedule but I can edit it. It seems like the elements are locked and on hidden layer. How can I solve this?
Solved! Go to Solution.
ā2023-11-23 02:39 AM
You should have set up a view in the View Map for your schedule.
Make sure it uses a layer combination where the zone layer is visible and unlocked.
Open the schedule with that view and you should be able to edit it.
ā2023-11-23 02:55 AM
Greatļ¼ļ¼ļ¼ Thanks
