dhnguyen
building a supended ceiling with stud
I want to learn how to build a suspended ceiling with metal stud framing so what when I create a section cut, I'm seeing the suspended vertical stud wall framing at x" on center instead of just a few horizontal lines depicting the ceiling material and the metal stud wall framing. Could you show me how to do that?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
1 Reply 1
BrunoH
Did you try the curtain wall tool ? It's really the best tool to do what you want.
The example below is not finished because I have used simple profiles and panels but it will be easy to replace them with the real ones and add the suspensions as jonction elements when needed. I had first to quickly create photorealist images.
ArchiCad 3.43 to 28
MacOS Monterey
