2011-11-22
07:29 AM
2024-12-31
02:10 PM
Molinda Prey
2011-11-23 07:48 PM
2011-11-26 04:29 PM
2011-12-02 11:30 PM
2012-03-15 05:34 PM
Dave wrote:Just came across this post looking for another, but if you are still wondering about this, it is a bug that still isn't fixed. The workaround is to choose the "move object" tool in the pet palette, then immediately re-choose the "move hotspot" tool. It will work until it doesn't, when you have to repeat the workaround.
When I select the pink node in the center of window marker, then "move node' in the pet palette, I expect to be able to move the maker, but it will not move. Any advice? seems like a bug.
