direction of linetypes
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-02-03
07:31 PM
2023-05-26
04:40 PM
Rubia Torres
2011-02-03
07:31 PM
However, I drew a rather complex layout for part of it, and have decided to change the flow direction. I'd rather not redraw the entire polyline. Is there a setting that will simply tell the line to reverse direction? This functionality would also be handy for things like the cold water line, so the CW is legible for lines that are drawn right to left.
thanks, any insight would be appreciated.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-03 08:33 PM
2011-02-03
08:33 PM
No. You can't edit the line to read one way or the other. All you can do is draw it from the other end if you want to change how it reads.
When you import drawings from another program, do the lines all come in as being drawn from left to right and top to bottom, or does ArchiCAD import the lines in the same way they were origianly drawn in the other program?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-03 09:46 PM
2011-02-03
09:46 PM
What you can do is create a new line that's mirror of the line you are using, select the lines you want to "flow" the other way, and then change those line's line-type to the mirrored line. I would think this would be faster than redrawing the lines the other way.
