dhnguyen
lines in layout
I want the lines in layout to be black in color when I print it in PDF, currently it comes out in red. Please show me how to fix this.
thank you.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
3 Replies 3
alemanda
Have you already tried to publish it in pdf?
If so and the result is still red, check the pen set
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
As alemanda said, change the pen set of your drawings in the layout to use black pens.
Or in the DOCUMENT OPTIONS for the PDF in publisher, you can choose to save PDF with colour, black & white or greyscale.
dhnguyen
thank you, I'm all set now.
DNguyen
ArchiCAD 18- 25
