2024-06-06 09:35 AM - last edited on 2024-06-11 11:35 PM by Laszlo Nagy
I have a strange experience don't know how it happened. Drawings show differently in section and plan with same pen set.
When i make a new model with Archicad 27 template it does not happen but when i use the "latest project setting" its shows up like this! Graphic overrides where off in both cases.
It could be a problem with the template i had been using. How can i correct it? can i migrate the existing model into a file with default template?
Kindly help!
Operating system used: Mac Apple Silicon 14 Sonoma
Solved! Go to Solution.
2024-06-06 09:43 AM
Have a look in the section settings.
You are probably using a 'Uniform pen for Cut Elements'.
2024-06-06 09:43 AM
2024-06-06 10:59 AM
Wow! Thank you. that solved and learned something new. I was going mad with this "phenomenon" 😀
that was a graet relief.
Thanks a lot!
