2007-08-09
03:51 PM
2023-05-19
10:21 PM
Gordana Radonic
2007-08-09 05:34 PM
2007-08-09 06:18 PM
2007-08-09 07:46 PM
2007-08-09 11:39 PM
2007-08-11 01:17 PM
Rich wrote:Next time you need to only reinstall the PDF driver. Its intaller is located within the ArchiCAD folder.
Had some luck. Reinstalled ArchiCAD on the computer. Whatever was causing the problem went away. ArchiCAD reinstalled the Amyuni PDF converter and it is now showing up when I go to print from the desktop and when I use the publisher.
Thanks for your suggestions and help!![]()
2007-08-12 05:31 AM
laszlonagy wrote:Are you sure that is still the case in AC11, Laszlo? The PDF Converter doesn't look like it exists as a separate application any longer. Maybe it has been bundled in with the main installation?
2007-08-12 09:25 AM
Link wrote:His signature says he is using AC10, this is why I wrote this.laszlonagy wrote:Are you sure that is still the case in AC11, Laszlo? The PDF Converter doesn't look like it exists as a separate application any longer. Maybe it has been bundled in with the main installation?
Link.
2007-08-13 02:16 PM
2007-08-13 11:20 PM
Rich wrote:Look for a folder name similar to this:
I will have to look at the ArchiCAD folder again. I did go through the information on the disk but did not see what might be a pdf installer. Does that show up as a separate icon within a folder? Yes, I am using AC10. I have installed all the updates from Graphisoft as they have been available.
