north arrow within drawing title
is there a way to place the OBJECT tools "north arrow" in the designated drawing titles? currently i set up the "NCS drawing title 12" and then add the north arrow externally on my drawing sheet. am i missing something?
4 REPLIES 4
Maybe you could script it in the 2D Script of the Title Object.
In the Script you would position your Origin to the place where you want the North arrow to appear, rotate it to the desired orientation, then call the North Arrow object as a macro, passing to it all needed parameters.
David Maudlin
laszlonagy wrote:
... rotate it to the desired orientation, ...
david:
If you are scripting, then you should be able to use the GLOB_NORTH_DIR Global Variable to get the project's North setting from the Sun dialog box.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
David Shorter
The Australian Title type has the north point shown with it set to face the current project north.
It also allows the north point to be switched off when used for sections and elevations.
So it is view dependent. I find this is better than placing it on the sheet / layout.
It also has the scale and back-referencing incorporated
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Hi David, do you know if this magical title still exists in Archicad 25? I used it many years ago in Australia but here in the US there is no title that includes a north point....what are the chances you'd be willing to share it with me?
