number of layouts in a folder
alemanda
Is it possible to have the number of sheets in a folder?
I would need to name the drawings with the following syntax
<NAMEOFFOLDER> - <LAYOUT_ID> / <NUMBER_OF_LAYOUT_IN_THE_FOLDER>
it seems that only the total number of layouts is available as autotext.
Am I missing something?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
3 REPLIES 3
Erwin Edel
As a workaround you can set a drawing on the last layout as reference and then use the Layout Number ref. autotext to maybe achieve what you want. Or have it dumbed down to manual input text / custom autotext string.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Eduardo Rolon
Besides the workaround this is already an option in AC21.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
alemanda
Thank you!
I already upgraded to AC21 but not used yet. I've just seen that option. Useful to match several naming standards.
AC27 latest hotfix
Win 10 Pro 64bit
