partial structure display for dimension
How can I get my dimensions to not turn off when I switch from entire model to partial structure display. The dimensions are to a slab with no composite finishes.
19 REPLIES 19
Eduardo Rolon
Grab the node and snap it to the same item. I have a GO that turns nonassociative dims red so I can see them.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
DGSketcher
Legend
I have tried to set this up & failed as I can't see how you determine a nonassociative dimension. Please can you share your settings?
Eduardo Rolon
Here you go.
AC28 US/INT -> AC08
another Moderator
DGSketcher
Legend
Thank you! I had missed the option under Model View.
ejrolon wrote:
Here you go.
Excellent tip and example usage of Graphics Overrides to highlight static dimensions, Eduardo! This should be in the Tips forum and part of everyone's setup when 'auditing' their model files. 🙂
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I wish it would be better way
Karl wrote:
Excellent tip
Thats true. It can make life easier.
Erwin Edel
I was thinking that, nice way to slap some people on the wrist for not dimensioning 'properly'
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
hi @Eduardo Rolon  sorry to dig this up and bother you again - your GO works great and the method too - though one thing I'm observing now is that after relinking, the ones that are now associative are still showing up in pink which should be the static ones - any clue why this is happening?
AC23 AUSTRALIA
MacBook Pro M1 2020 8GB Memory | macOS Monterey 12.3.1
You have to make sure that every node is associated.
Even if only one node is static, the GO will override the entire dimension.
thanks @Barry Kelly - indeed that was the case. It feels like AC has a trend of "Apply to all" 😉
AC23 AUSTRALIA
