2018-12-05 02:55 AM - last edited on 2023-05-22 11:53 PM by Gordana Radonic
2018-12-10 01:11 PM
another Moderator
2018-12-10 03:47 PM
ejrolon wrote:I have tried to set this up & failed as I can't see how you determine a nonassociative dimension. Please can you share your settings?
I have a GO that turns nonassociative dims red so I can see them.
2018-12-10 04:49 PM
2018-12-10 05:54 PM
2018-12-11 06:01 PM
ejrolon wrote:Excellent tip and example usage of Graphics Overrides to highlight static dimensions, Eduardo! This should be in the Tips forum and part of everyone's setup when 'auditing' their model files.
Here you go.
2018-12-12 11:16 AM
ejrolon wrote:I wish it would be better way
Grab the node and snap
Karl wrote:Thats true. It can make life easier.
Excellent tip
2018-12-13 10:36 AM
Karl wrote:I was thinking that, nice way to slap some people on the wrist for not dimensioning 'properly'
Excellent tip and example usage of Graphics Overrides to highlight static dimensions, Eduardo! This should be in the Tips forum and part of everyone's setup when 'auditing' their model files.🙂
2022-05-20 02:55 AM
hi @Eduardo Rolon sorry to dig this up and bother you again - your GO works great and the method too - though one thing I'm observing now is that after relinking, the ones that are now associative are still showing up in pink which should be the static ones - any clue why this is happening?
2022-05-20 03:20 AM
You have to make sure that every node is associated.
Even if only one node is static, the GO will override the entire dimension.
2022-05-20 03:26 AM
thanks @Barry Kelly - indeed that was the case. It feels like AC has a trend of "Apply to all" 😉
