2026-08-26 09:20 PM
I am on MacBook , so in order to SAVE file in PDF, I have to go through File > PRINT.... it is not through the standard routine, so I don't have choice on DPT setting either... in this setting I can only choose to chase in quality Draft, normal or high.
I just downloaded my project schedules in PDF, I kid you not, it is 140MB in normal quality, but draft being similar. I use PDF PRO, which have feature to make files smaller but it ends up being still 90MB. If I save it that way, the layout open VERY slow, IF. When I go to office to print it, the printer crash and I am unable print it.
I tried to simplified certain objects, even removing textures (ouch, because that's part of specifications), but nothing really helps. I know there used to be an option to find heavy objects in archicad but I can't no longer find it.
Anyone who can help please?
Solved! Go to Solution.
2026-08-27 02:19 PM
I can see for the print, if the company can download this type of browser and print from there
but I need to regularly open the pdf…. So it would be helpful to be able to open it without computer crashing.
2026-08-27 02:26 PM
Gosh. There is. Was it always there?? 🫣 thank you. Oh well, this is embarrassing. I never noticed there was pdf option to save as and adjust the DPI. The solution that came from Archicas was to do it through print-save us.
thank you.
2026-08-27 03:08 PM
@cocoloco schrieb:
My whole file is 140MB. Not a schedule…?
So what's the file size now with 'Save as'?
2026-08-27 07:54 PM
I saved all 50 layouts in 600 DPT , some pages including renderings (from third party) and it's about 27MB now and it opens quickly. I could potentially still adjust this through PDF expert. But this is already huge improvement. Thank you.
