print trace
Dave Brach
I would love to be able to put a trace reference on a layout and have it print to pdf
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
16 REPLIES 16
DGSketcher
Legend
Olde skoole draughting?
Graphic overrides! I have a rule that fades everything to grey and then build up the view with other rules to highlight the essential features. Your other option is to create the monochrome images as views and add them to your layout. You could even do the latter with a monochrome pen set if you don't want to use GO's and apply it to the layout view settings.
Stress Co_
It works for me now... with one small caveat.
The trace reference drawing is hidden by coverfills on the layout drawing.
The "make fills & zones transparent" button (on the Trace palette) is for display only.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Dave Brach
thanks, I had not thought of graphic overrides, but I'll play around with that...
AC26 MBP OS Ventura
Dave Brach
Marc, that "print reference" checkbox is grayed out for me for some reason.
AC26 MBP OS Ventura
Stress Co_
Double check that your trace reference is active.
Otherwise... I can't think why.
Dave Brach
yes, that was it, so I got it to work. thanks! however in the print dialog box, in the "arrangement" secction, mine shows sheets 5x3, and it is printing a 3' x 2' layout on what looks like 15 separate 8.5" x 11" sheets. any idea how to change that?
AC26 MBP OS Ventura
Stress Co_
You need to change your paper size in "Page Setup".
Dave Brach
Is there any way to get trace reference to show using the publisher set, instead of printing an individual layout by going to "File" then "print"? I typically use the publisher set to print all pdf layouts.
AC26 MBP OS Ventura
Dave Brach
my other problem is that the trace reference view is set to renovation filter "planned status" but it shows up in the published pdf as "show all".
AC26 MBP OS Ventura
