2007-11-16
12:10 PM
2023-05-19
10:21 PM
Gordana Radonic
2007-11-16 01:57 PM
2007-11-16 03:28 PM
2007-11-16 03:43 PM
2007-11-16 10:09 PM
Thomas wrote:Thomas,
A wish - since you need these views for DWG export only, they should be translator settings - strip fills (drawing/cover/cut), hairlines only, etc etc.
2007-11-16 11:37 PM
jagostinho wrote:Well, in case of Layers: if you save a Layer Combination with the View, then later the View refers to the Layer Combination. So in case a Layer is added, you can just modify/edit the Layer Combination and the result will be correct. This is why a View should not contain a custom layer combination in it, instead always a named and saved Layer Combination.
laszlo: many thanks for the tip. the down side to it is that I would need to update both pdf and dwg views in case something changes (e.g., layer add)
thomas: that was where I first look - in the translator settings - and found nothing. a wish indeed it is!
2007-11-17 10:42 AM
Erika wrote:Done, along with a couple of others that I've been nagging about.Thomas wrote:Thomas,
Can you make this a wish?
2020-10-08 12:30 PM
2020-10-08 12:41 PM
