publishing to PDF from plotmaker
I may be wishing for too much here, but is there a way to set up publisher to
create one PDF file, with each view as a page, rather than one PDF file for each view? I was thinking something along the lines of setting the PDF converter to use a default filename, and setting it to "append to existing file" on overwrite. But this doesnt seem to work. anyone have any ideas how to do this?
cheers,
dan
1 REPLY 1
or you could just check "merge PDFs into one file"
