2024 Technology Preview Program
trace reference in layout book
Dave Brach
When in the layout book, why is it that, when I set the trace reference to another story level the "reset to default position" does not work? For instance if I have the second floor plan on a layout and set the first floor plan to show as trace reference, and reset to default position, the plans do not line up.
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
5 REPLIES 5
Could you post a screenshot of this?
I cannot reproduce this on the latest build of ARCHICAD 21.
Are you using ARCHICAD 21 or an earlier version? It might be a good idea to fill in your signature in your Profile with this data so it is easier for us to help you.
Dave Brach
hi Laszlo; attached is a sceenshot. This is what I do: place a second floor plan on a layout; set first floor plan to trace reference; go to Trace >reset to default position; and the two plans do not line up. By the way, my signature is always on, you don't see it?
AC26 MBP OS Ventura
Oh yeah, I can see your signature, I think I just did not see it while writing the reply (forum feature), and thought you do not have a signature.
About the issue: I do not really have any ideas about what could be causing this behavior. I wonder if you are on the latest update. And if not, if updating to it makes any difference.
Otherwise all I can do is to report it to GRAPHISOFT for investigation.
felcunha
It happened to me sometimes when I had the plan view rotated. Try to reset it if it was the case.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Dave Brach and felcunha,
I have tried this myself, but it didn't do this for me. Could you send me your projects in a Private Message, so that I can try that myself, and see what might cause it? Please also send pictures/instructions about where should I look.
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
