dhnguyen
view source setting
I'm using ArchiCAD 16. I have several layer combinations set up for plans and RCP. I kept on changing the view settings to what i wanted to be, for example, the demo plans should have demo layer combination setting. However, it keeps on reverting back to whatever layer setting that my plan shows.... How do I look my view settings so I dont have to reset it every time?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
1 Solution
I had this inkling that was the case because this distinction between Viewpoints and View is ARCHICAD is an important thing to know.
So if you are in the Project Map, you will see the list of Viewpoints. Viewpoints are the various ways of representing and displaying the model. These correspond to usual architectural conventions in that there is a Floor Plan Viewpoint, there are 3D Viewpoints, Section Viewpoints, Detail Viewpoints, Schedule Viewpoints etc.
There are settings that influence what things are displayed and how things are displayed in Viewpoints. These include: Layer Settings, Scale Settings, Zoom Factor, Model View Options, etc, etc.
Now, when you save a certain state of a Viewpoint with the settings it has at a given point, you create a VIEW. So a View is a Viewpoint with its settings capture. These View can then restored, which means that when you restore, or activate a View, it will activate the Viewpoint it was saved from and restore all those above mentioned settings that were in effect when the View was created. View are shown in the View Map of the Navigator.
So I think when you said "View", you were talking about "Viewpoints" and their settings, and what you want to do is create Views so that you will have the exact settings of Viewpoints stored so you can restore them later when needed.
Go to post
7 Replies 7
Are you familiar with the difference between Viewpoint and Views?
Are you familiar with the difference between the Project Map and the View Map?
dhnguyen
I am not familiar with viewpoints and views.
I'm becoming familiar with project map, not with view map. I clicked on the view map tab and I'm seeing many views created by someone else who owned this drawing. Are some of these views mine?
I am an advanced AutoCAD user, a beginner in ArchiCAD.
DNguyen
ArchiCAD 18- 25
dhnguyen
Thank you, that solved my problem. I simply just need to rename those views in the View Map and replace them on the layout book and so far they stay permanently as I want to be.
DNguyen
ArchiCAD 18- 25
Reysol
Hi Laszlo,
I am also new to Viewpoints and Views and have not had a good grasp of how to use these two items efficiently and properly.
I recently watched a tutorial explaining the contents displayed in a Viewpoint or a View. Here is the tutorial links pasted below.
https://www.youtube.com/watch?v=KB6dU_eDl2E (What TABs display when activated)
Let me quote some content from the tutorial, which really makes me confused.
‘When opening a View, the previous settings in the Project Map will be overwritten.  In another word, the Project Map inherits the setting stored in the Views. ’
‘If you activate a Viewpoint in the Project Map it will be displayed in its TAB using the View Settings used by the last active TAB, or in other words, it will inherit its View Settings.’
‘Similarly, if you use any of the “Show Selection or Marquee in 3D”, “Show All in 3D” or “Show Stored Selection or Marquee in 3D” commands to activate the 3D Viewpoint, it will be displayed in its TAB using the View Settings used by the last active TAB.’
Here come my questions.Let me give you a scenario here. For example, the Ground Floor Plan (a Viewpoint) has its Layer combo called 001, and the East Elevation (a View) has its Layer combo named 002. So, after working in the East Elevation (View), I open the Ground Floor Plan (Viewpoint) and the Layer combo of the Ground Floor Plan (Viewpoint) will be overwritten to be 002?
If yes, how can we get the previous and original setting (Layer combo 001) back for the Ground Floor Plan (Viewpoint)?
If double-clicking a TAB will restore the View Settings stored in the source View of the TAB, does this apply to Viewpoints when they get overwritten by the last activated TAB?  Or should we try to right click drop downs and choose ‘Get Last Settings’?
Thank you
When you choose a viewpoint from the Project Map, they do not have original setting - just the setting you have currently chosen yourself.
You will notice the icons in the TAB bar for Project Map viewpoints are black.
When you choose a view from the View Map, they have their particular settings saved with them.
You will notice the icon in the TAB bar is blue.
If you ever see a (!) next to the icon, you know it is not using its standard settings.
Double click the tab and it will restore the default setting for that view and the (!) should disappear.
What I have just noticed though, is some elevation views I open, straight away have the (!) next to them and yet others don't.
At first glance I don't see anything odd in the settings - but there must be something somewhere.
A double click on the tab fixes it.
But as soon as I go to another tab and then come back to that elevation, the (!) is back - but I see no changes in the settings.
It is only happening for one group of elevations to me - all the others are fine
I may have to re-save my template.
Reysol
Thank you Barry,
So, a Viewpoint does not inherit any view settings from the last activated View tab anymore, as of Archicad 20?
Also, I found this in the community. I am gonna give it shot at my end.
https://community.graphisoft.com/t5/Design-forum/Exclamation-Mark-in-Tabs-not-resolving/td-p/242309
