2023-05-10 03:06 PM - edited 2023-05-10 04:52 PM
Doesn't the 3D script take the master scripter's variable values?
In the 2d script, it takes a value.....
Shouldn't I use an if statement?
2023-05-10
05:21 PM
2023-05-16
04:56 AM
WALL_FLIPPED doesn't work in 3D
WALL_FLIPPED doesn't work in 3D - Graphisoft Community
I still don't understand.
Passing the value from Master to wall_flipped as another variable does not work.
The conclusion seems to be that all values should be done in master and only those values should be used.
I spent the whole day on this today.
I believe that bugs should be fixed as soon as possible.
Master script
IF ((SGN(SYMB_ROTANGLE) = 0) & (WALL_FLIPPED = 0)) Then
npen = 1
ENDIF
IF ((SGN(SYMB_ROTANGLE) = 0) & (WALL_FLIPPED = 1)) Then
npen = WALL_SKINS_NUMBER
ENDIF
3d script
print "xx"
print npen
TEXT 0.3, 0, npen
And this was also tested at 25.
Can not be done.
Value does not change.
How can i solve it?
2023-05-10 08:12 PM
One of the doors I wrote for composites I figured this out, but I don't use composite walls with more than one skin anymore so that door is somewhere in my archives.
Assuming I understand what you are after it is possible but it will be a minute before I have time to go digging.
2023-05-11 01:58 AM
i used the WALL_MAT_A, WALL_MAT_B system to identify outside vs inside of walls (before Archicad 22 introduced WALL_FLIPPED variable)
it is more complicated than "WALL_FLIPPED",
but
the "WALL_FLIPPED" does not work in the 3D Window/Elevation window...
but does work the 2D window.
2023-05-11 03:45 AM
Where should I look to learn how to identify the exterior and interior of a wall with WALL_MAT_A WALL_MAT_B? Is there a gsm where I can see the code?
2023-05-11 05:46 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2023-05-11 08:24 AM
thank you. ^^
I will study hard.
2023-05-11 08:25 AM - edited 2023-05-11 08:25 AM
Hopefully that is what you were looking for
2023-05-21 05:59 AM
It is judged that WALL_MAT_A is not related to WALL_FLIPPED, but rather related to SGN (SYMB_ROTANGLE).
Therefore, it seems that WALL_MAT_A value cannot determine whether it is inside or outside in 3D.
I don't understand the code you gave yet, but it seems there is an IF statement option, and I'm thinking of turning it on in 3D.
Am I wrong?
2023-05-22 03:17 AM
I believe I have determined inside from outside using WIDO_REVEAL_SIDE.
IF WIDO_REVEAL_SIDE = 1 then
WALL_MAT = WALL_MAT_A
else
WALL_MAT = WALL_MAT_B
endIF
