2021-05-17
05:34 PM
2021-09-14
09:11 AM
Noemi Balogh
Solved! Go to Solution.
2021-05-18 12:07 PM
DIM fillsIndexArray[] DIM fillsNameArray[] FOR n=1 TO 1000 fillsIndexArrayAnd then this code in User Interface script:=n fillsNameArray =STR(n, 1, 0) NEXT n VALUES{2} "customFill", fillsIndexArray, fillsNameArray
DIM pixIdxArray[]
m=1
FOR n=1 TO 1000
rClass = REQUEST ("class_of_fill", n, class)
IF rClass THEN
IF class=3 THEN
rName = REQUEST ("Name_of_fill", n, name)
IF rName THEN
fillsIndexArray=n
fillsNameArray=name
pixIdxArray=''
m=m+1
ENDIF
ENDIF
ENDIF
NEXT n
UI_INFIELD{4} "customFill", 5, 65, 200, 20,
8, "",
0,0,0,0,0,0,
pixIdxArray, fillsNameArray, fillsIndexArray
Result is showing on preview image. You can also add additional code to re-organise fills list, that it would follow alphabetical order. If you need help with that - I can share the script about it too.
2021-05-17 05:49 PM
2021-05-17 05:55 PM
2021-05-17 07:18 PM
2021-05-17 10:46 PM
2021-05-18 11:02 AM
Podolsky wrote:True .... 😞
To be honest - this limitation when some requests are not working in Parameter script make a lot of nice things to do in GDL impossible.
2021-05-18 12:07 PM
DIM pixIdxArray[]
m=1
FOR n=1 TO 1000
IF rClass THEN
IF class=3 THEN
IF rName THEN
fillsIndexArray=n
fillsNameArray=name
pixIdxArray=''
m=m+1
ENDIF
ENDIF
ENDIF
NEXT n
8, "",
0,0,0,0,0,0,
2021-05-18 12:48 PM
2021-07-21 04:00 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2021-07-21 06:04 AM
Lingwisyer wrote:Please look as Schedule Setting Tool from my library, at the end of Parameter script there is subroutine that organising arrays in alphabetical order.
Hey Podolsky, how would you go about achieving this? Also, is there a way to check if a fill exists or not?
I saw this thread but do not get what is happening...
Ling.
