GDL
GDL:the angle of inclination
iu-tamura
Is it possible to add hotspots that change the angle of inclination, such as beam elements, to a GDL-created shape such as a cylind on a sectional view??
I know this is difficult because there is no reference line, but could this be accomplished by using some sort of 3D shape command?
10 REPLIES 10
Lingwisyer
Guru
Using the standard HOTSPOT command with the flags 4 to 7. If you want your hotspots to move with the vertices, you would just need to incorporate some trigonometry, sin and cosine, into the x & y inputs to bound it to a circle.
Or, given your example, in which the object is just bound to the one axis, you can skip this, since you are not bound to a circle, and just define a hotspot for the z-axis. Use cos(pitch) to calculate your top / bottom hotspot difference. If you wish to have move flexibility than that it could get complicated very fast...
Ling.
Thanks for the reply.
With the method you described, if I rotate a simple shape like a beam, for example, will the cross sections at both ends be oblique according to the angle of rotation instead of perpendicular?
I am attaching a diagram.
Lingwisyer
Guru
To do that I would use the CUTPLANE commands and extend the profile and arbitary amount in both directions to ensure it is vertical.
!Top
CUTPLANE 1, 0, 1, 1
!Bottom
CUTPLANE 1, 0, 1, 0
julienK
no,  it will just rotate the shape as is.
One way to achieve this would be to use XFORM
Isn't XFORM reserved for the Grand Master of the Dark Arts? 😉
DGSketcher
Legend
I use TUBE for all my beams.
@iu-tamura You may find Put & Get useful for your beam profiles. See if you can find a copy of GDL Cookbook 3 by David Nicholson-Cole on the 'net. It is old but still relevant for learning GDL.
Just pull up the wikipedia page  for transformation matrix , copy/paste, profit.
Thank you.
I have recently started learning the GDL, so I am glad to know about it.
I'll take a look at the book as well.
So, you mean that you use beam profiles with the GDL TUBE command?
It is possible. In my case I am creating my own selectable profiles for specialist objects. If you want to know how to use AC Complex Profiles for your beams then you won't find that in CB3. I don't like AC's Param-O add-on, but what I found useful was placing a complex profile beam in a Param-O object and then looking at the generated GDL code with the GDL manual.
