Daniel Pataki
Linking properties into GDL Parameters?
Hello there,
i am looking for a possibility to link a property (made in Property-Manager) to a GDL Parameter, in my example I want to define the room number through a property.
What I could already manage to link the element-id, under Parameterscript:
parameters ROOM_NUMBER = GLOB_ID
I also could find the code for my wished property (e.g. <PROPERTY-4CCC5747-F313-44B1-AA12-55B7B4EA9DA9>) through text-content, but it doesnt work in the parameter-script ... Is it even possible? If yes, please help with the code! 🙂
(Using Archicad 24-25)
Archicad BIM-Expert
https://www.a-null.com/
17 Replies 17
This is so freaking amazing thank you
The only down side, I'm guessing you can't push parameters back to the object. This method is for listing information not modifying parameters through properties
Lukas Oelmueller
I finaly made a video to this Topic.
Mac OSX - up to date
GER Archicad Full, Up to date
Fire rating is also mapping BTW
Lukas Oelmueller
@Piotr Dobrowolski
Thanx for sharing. It doesn't help though, since it's another Parameter for Doors and Windows. Not Objects or Rooms 😞
kuvbur
Try using the addon to transfer property values to parameters. Any object type is supported, including doors, windows, light sources, etc.
https://github.com/kuvbur/AddOn_SomeStuff
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Lukas Oelmueller
Hi @kuvbur ,
I cant get the add-on to Work.
Tried 27 an 28 on a mac.
Thanx
Stefan L_
Got it - worx!
Still flashed! 😍
AC27 on WIN
Stefan - AC ...-29GER, WIN11
