Mario Sacco
Store Profile data in GDL Parameters using Request
I'm trying to extract data from a profile and memorize them in the parameters of an objects using REQUEST.
It seams this option is not possible.
This is the code I used in parameter script.
dim geometry []
dim nnn[]
dim xx[]
dim yy[]
n = REQUEST ("Profile_default_geometry", ar_profile_type, geometry)
nnn[1] = geometry [1]
for t = 1 to nnn[1]
	xx[t] =  geometry[1+(t-1)*5+1]
	yy[t] =  geometry[1+(t-1)*5+2]
next t
parameters xx = xx
parameters yy = yy
Do you never have this kind of issue?
Operating system used: Mac Apple Silicon Sequoia
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
2 Replies 2
Lingwisyer
Guru
Curious to know what is the purpose of this?
AllanP
Not what you want to hear,  in the GDL manual:
Compatibility: introduced in Archicad 21.
PROFILE_DEFAULT_GEOMETRY
n = REQUEST("PROFILE_DEFAULT_GEOMETRY", name_or_index, n1, n2, ..., nm,
x11, y11, edgeVisible11, vertEdgeVisible11, additionalStatus11, ...,
x1n1, y1n1, edgeVisible1n1, vertEdgeVisible1n1, additionalStatus1n1,
x21, y21, edgeVisible21, vertEdgeVisible21, additionalStatus21, ...,
x2n2, y2n2, edgeVisible2n2, vertEdgeVisible2n2, additionalStatus2n2,
xm1, ym1, edgeVisiblem1, vertEdgeVisiblem1, additionalStatusm1, ...,
xmnm, ymnm, edgeVisiblemnm, vertEdgeVisiblemnm, additionalStatusmnm)
Returns the original geometric data of the profile identified by name or index.
Expression returns 0 and contains dummy return values (empty string or 0) if used in parameter script (or master scripts run as parameter script), causing additional warning.
You can use the values in the script, but you cannot use the "Parameters" command to assign the values to the objects parameters.
I hope this is useful.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
