a month ago - last edited Tuesday
Operating system used: Windows win11
a month ago
4 weeks ago
@Miha Nahtigal — fair point, and you're right that turning curves themselves aren't new. The reason for an addon rather than a GDL object comes down to what GDL can't reach:
So the GDL objects aren't wrong, they just stop where the interesting part starts.
a month ago
Autoturn from Transoft is only released for Revit and Autocad.
This addon has a lot of potentials to fill up the gap of real vehicle turn simulation.
We constantly design parking areas and we are not sure completely how they perform.
Those GDL objects available have limited options.
I am really interested in this addon and I can support any beta testing.
Great News @catalinpopa
4 weeks ago
Thanks, and yes please. Parking areas are the best possible test case, since that's where the multipoint and clearance issues actually bite. If you can share a couple of real parking layouts you've had trouble validating, that would help me make sure the solver handles the awkward cases and not just textbook geometry.
4 weeks ago
Single manauver turns are covered decently with the old CI objects and the new default GS objects. The main issue I find with these is that you cannot represent flowing turns cleanly, or do multipoint, so you end up drawing over them to get the end representation...
4 weeks ago
@Lingwisyer — that's exactly the gap I'm targeting. The CI and GS objects handle a single clean maneuver well enough, but flowing turns and multipoint are where everyone ends up drawing over the output by hand. Continuous path following and multipoint sequences are the core of what the addon does, not an add-on feature.
3 weeks ago
This is definitely an object worth developing. On larger projects you generally have a traffic engineer that tests all this stuff for you, but it's a lot of trouble to get them to test every design iteration you want to look at. Much better to 'sanity check' in house before getting final sign-off from the engineer. Thumbs up from me.
3 weeks ago
Hi! I'm desperately trying to create roads on a logistic hub project on a steep location and your add-on would help a lot. What would it need to work on macOS?
3 weeks ago
Hi! I m working on it. I think this week it will be done
Tuesday - last edited Tuesday
Can u try the mac version?
3 weeks ago
That’s a good step in the right direction!
