We value your input!
Archicad Start Edition 2022
Gabriela Freitas
Archicad Start Edition (SE) 2022 is a professional BIM solution with critical features most smaller practices need. Read this article to learn more about its capabilities.
Archicad Start Edition 2022 was released on February 17th, 2022. Based on the technology of Archicad 25,  Archicad Start Edition (SE) 2022 is a professional BIM solution with critical features most smaller practices need.
Serving as a base for the latest Archicad Start Edition, Archicad 25’s robust, well-tested engine satisfies the needs of a smaller practice. Archicad Start Edition 2022 provides the full power of Archicad 25’s BIM-based streamlined documentation workflow, allowing the project model to stay live until the very end of the design documentation phase: it helps keeping architects in the state of the creative design flow with as little disruption as possible. (To take advantage of the entire range of Archicad features and benefits, upgrade to the full version of Archicad at any time and continue editing all your previously started projects with it.)
Archicad Start Edition 2022 is a BIM solution for smaller architectural practices that contain all the features of Archicad 25 that are critical for them but those features that have little or no importance for them are omitted.
Archicad Start Edition 2022 is not available on all markets.
To purchase Archicad Start Edition 2022, contact your Archicad reseller.
Find information about the previous versions of Start Edition in this article.
Archicad Start Edition 2022 Compared to Archicad 25
Modelling
The SE contains all the necessary tools to create a proper Building Information Model, with everything you need in the residential scale, like profiled or composite structures, priority-based junctions, the Shell tool, the Morph tool, and GDL objects.
Limitations:
- No Curtain Wall
- No Point Cloud data import and visualization
- No MEP Modeling
- No PARAM-O add-on
 The complete 2D feature set of Archicad is part of the SE package: model-based documentation, 2D tools, layout books, etc.  There are no limitations in this area.
Visualization
Archicad Start Edition provides basic visualization techniques like real-time shaded 3D environment, a simple rendering engine (the so-called basic engine), 3D Styles, and the ability to save BIMx Hyper-models.
Limitations:
- No advanced (Cinerender) photorealistic rendering
- No Sketch rendering
Interoperability
Latest IFC, BCF, DWG, and DXF file exchange capabilities to enable full model-based and hybrid coordination workflow with consultants.
Limitations:
- No STL export
- No Rhino export/import
- No Grasshopper-Archicad
- No Solibri Connection
Collaboration
The Archicad Start Edition doesn’t contain any Teamwork feature because it’s intended for solo architects. It provides full control of IFC Preferences and Managing Classifications in IFC Import/Export.
Limitations:
- No Teamwork
- No Hotlinked Modules
- No XRefs
- Limited External Drawing support
- No Collision Detection
- No Structural Analytical Model workflow
- No 3D Model Compare
Productivity Tools
The main difference between Archicad Start Edition and Archicad Full version is productivity. You can do everything with the SE version, but you can work faster with the Full.
Limitations:
- No Renovation
- No Publisher
- No Revision Management
- No Link element height to stories
- No Import element property data from Excel
- No JSON-Python API for Archicad
- No Energy Evaluation
- No Physical Model Check
- No Export/Import Issues via PDF markup
Perfomance
The Archicad Start Edition 2022 is configured to manage small-scale projects with rapid software reaction, but it’s not ideal for large-scale projects.
Limitations:
- Multithreading capable algorithms use max 2 cores of the CPU
Check the new features comparison chart below to see the exact differences between Archicad 25 full version and Start Edition 2022.
Archicad 25 new features available in Archicad Start Edition 2022
New feature of Archicad 25
Type
Included in SE2022
Navigation Improvements
Workflow
yes
Create Polygonal Openings in any 2D or 3D view
yes
Stair Improvements - New tread symmetry combinations for all winder types - New Stair Landing contro...
yes
PARAM-O Improvements
Add-On
no
Load Handling in Structural Analytical Model
Open BIM
no
Automatic Export Mapping of Manufactured Profiles
Open BIM
no
Custom Alignment of Replacement Profile (1D Members)
Open BIM
no
New Offset Adjustments/2D Cutback Improvement
Open BIM
no
Connection Range Improvements
Open BIM
no
Support for All Released SAF Versions
Open BIM
no
Create Structural Supports - Streamlined Input
Open BIM
no
Native Survey Point
Workflow
yes
RFA and RVT Geometry Exchange
Open BIM
no
Archicad - Solibri Connection
Open BIM
no
Surface Textures on Sections/Elevations/Interior Elevations Viewpoints
Visualization
yes
Surface Based Fills
Visualization
yes
Modular Kitchen Cabinets
yes
Life-Like Interiors
yes
Track Changes and Model Compare improvements
Workflow
no
Object Settings Elevation and 3D Previews free rotate
Workflow
yes
Updated Line popup
Workflow
yes
Updated Surface and Fill Settings - Realistic soft shadow and cover fill option on top of textures
Visualization
yes
Support for Rhino 6 and 7
no
Export Building Material Classifications as IFC Classification References
Collaboration
yes
Native Metal graphics technology replacing Open GL on macOS
Visualization
yes
Archicad Survey Point Supported in RVT Workflow
Collaboration
no
Redshift by Maxon rendering engine – faster, GPU-based rendering
Visualization
no
Zones appear on Section/Elevation/Interior Elevations
yes
Label Zones with auto-text and/or GDL based Labels, just like other elements
yes
Schedules: control Merge Uniform Items per fields on a more granular level
yes
Additional Graphic Override Improvements
Workflow
yes
New transparency control for custom RGB Surfaces overrides
Workflow
yes
Option to hide contours in model views of Cut and Uncut parts of elements
Workflow
yes
Update properties in hotlink modules
Workflow
no
New command to check for the overlap of linear elements - Partial overlap check on linear elements: line, polyline, arc, wall, beam, column
Workflow
no
Graphic Override
Workflow
yes
Technical Information
Hardware and Software Requirements
Hardware and software requirements are modified from time to time. For up to date information on system requirements, please follow this link: www.graphisoft.com/support/system_requirements/
File Compatibility
Archicad Start Edition 2022 will be able to open files that were created with:
  • Start Edition 2006 or newer versions
  • Archicad 8.1 and 9
Start Edition 2022 files can be opened with:
Saving projects files:
Files created in Archicad Start Edition 2022 can be saved as:
  • Archicad SE 2022 Solo Project (*.pln)
  • Archicad SE 2022  Project Template (*.tpl)
  • Archicad SE 2022 Archive Project (*.pla)
Installing
In the following steps, we take you through the process of installing the Archicad program at a stand-alone workstation. Archicad Start Edition is available by electronic delivery or on DVD, depending on your market. For details, contact your distributor.
Electronic Delivery
Download Archicad SE 2022 to your computer, then proceed with the installation.
Install from DVD
Insert the Archicad SE 2022 DVD into your computer’s DVD-ROM drive. To avoid performance issues, it is recommended that you first copy the installer from the DVD to your computer and install the program from there.
Macintosh users
1) Go into the “Mac” folder.
2) Copy the Archicad-Start-2022....dmg file to your computer.
3) Double-click the dmg file.
4) In the appearing volume, double-click the ArchicadInstaller.app to start the installation wizard.
Windows users
1) Go into the “Win” folder.
2) Copy the Archicad-Start-2022....exe file to your computer.
3) Double-click the exe file to start the installation wizard.
After that, follow the detailed installation instructions to install Archicad Start Edition 2022. If you encounter any problem during installation please check this page.
Uninstalling
Windows:
To uninstall Archicad Start Edition 2022 from Windows, it is best to use the “Programs” or “Add or Remove Programs” utility, accessible from the Control Panel.
You can also browse to your Archicad Start Edition 2022 folder and execute the uninstaller in the Uninstall.AC subfolder.
macOS:
On a Mac, navigate to the “Uninstall.AC” folder in your Archicad Start Edition 2022 folder, and select the “Uninstall.app” application.
The Uninstall Wizard will remove files which were installed by the Archicad Installation Wizard. CodeMeter and associated components are not removed.
The uninstaller will not remove any files you have created in the Archicad main folder - e.g. Archicad project files that you saved into the Archicad main folder.
For Silent uninstall check the Install Guide.
 Licensing
When you start Archicad, the program automatically checks to see if you have a license available. If so, you are ready to work. To update, download and otherwise manage your license keys, use the License Manager Tool. The License Manager Tool is automatically installed to your computer as part of the installation of Start Edition. It is also available for download at:
www.graphisoft.com/downloads/licensing/
Hardware Key
The Hardware Key (Dongle) contains your license information on a USB stick. Before you start using the latest version of Archicad Start Edition, this Hardware Key must be updated. For the update process, start the License Manager Tool (LMT) and follow the directions. See: https://help.graphisoft.com/lmt/. Now you are ready to use Start Edition 2022.
Note: After updating your license key to Archicad Start Edition 2022, you can still use all earlier Start Edition versions. (To run SE 2008 or SE 2009, you must have its latest hotfix installed.)
Software Key
The Software Key is a software-based license. Using the License Manager Tool, a software key can be downloaded from the License Pool to a local client Computer. To download a software key, start the License ManagerTool (LMT) and follow the directions.See: https://help.graphisoft.com/lmt/.
If you are using a single license and plan to work on a different computer, you should upload the software ey to the License Pool, so that you can access it from a different location. (Internet connection is required.)
Demo Mode
When you start Archicad, the program automatically checks to see if you have a license available. If you don’t have a license at all, you can continue in Demo Mode. Demo Mode gives you full functionality except file saving. Use Demo mode to open, view and try out functions.The unavailable commands and menu items are disabled, and the Archicad title bar changes to Archicad SE 2022 Demo. Your Archicad program may also be restricted to Demo mode for the following reasons:
  • No key is attached to your computer
  • All of your Archicad licenses are in use
  • Your Hardware Key is defective
  • CodeMeter service is not running
Lost or Defective License Key
In case of a lost or defective License Key, contact your local Archicad distributor.
Add or Repair Archicad Start Edition 2022
If you already have Archicad Start Edition 2022 installed, and start the Installation Wizard, you are given two options:
1) Add will add new features to your current installation. You will see all available features in a list and you can check features to be added to your current installation.
2) Repair will reinstall Archicad Start Edition 2022 with the features of your current installation.
  • The Repair process will revert your Archicad Start Edition 2022 version to its default settings. After Repair, you must reinstall the latest Archicad Start Edition 2022 and Library updates.
  • Project files you saved into the Archicad SE 2022 folder will not be deleted or overwritten by the repair process.
Updates for Archicad Start Edition 2022
To check for available updates of your localized version of Archicad SE 2022 or Archicad SE 2022 libraries, start Archicad SE 2022 and do any of the following:
  • Use Help > Check for Updates
  • Open the Action Center (File > Info > Action Center) and select the Updates item to see notifications on any updates available for download.
  • For automatic checking: Set the Check for Updates options in Options > Work Environment > Network and Update. You will be notified if a new library or program version matching your Archicad language version is available, which you can then download. The Check for Updates command takes you to the Graphisoft update website. If there is a new update patch available, the web page will automatically offer you the updater package that fits your current Archicad installation. You can find other downloadable materials (example files, goodies etc.) at: www.graphisoft.com/downloads/
Note: If you have an updater patch installed and use the Add/Repair function of the Archicad SE 2022 Installer, you will be prompted to re-apply the updates after the modification or repair is carried out.
Comments
KUBUS
I'm looking for a total Comparison between Archicad 25 and STAR(T) Edition versions. Like there was for Archicad 24.
Holger Kreienbrink
Susanne_NBG Sweden
Does Archicad Start Edition work with Twinmotion (Mac / Windows) or Enscape (for Windows)?
Is it the add on "DatasmithARCHICAD25Exporter.bundle" that is used for Twinmotion then?
