on 2022-02-17 07:10 PM - edited on 2022-03-01 12:06 PM by Emoke Csikos
Archicad Start Edition 2022 was released on February 17th, 2022. Based on the technology of Archicad 25, Archicad Start Edition (SE) 2022 is a professional BIM solution with critical features most smaller practices need.
Serving as a base for the latest Archicad Start Edition, Archicad 25’s robust, well-tested engine satisfies the needs of a smaller practice. Archicad Start Edition 2022 provides the full power of Archicad 25’s BIM-based streamlined documentation workflow, allowing the project model to stay live until the very end of the design documentation phase: it helps keeping architects in the state of the creative design flow with as little disruption as possible. (To take advantage of the entire range of Archicad features and benefits, upgrade to the full version of Archicad at any time and continue editing all your previously started projects with it.)
Archicad Start Edition 2022 is a BIM solution for smaller architectural practices that contain all the features of Archicad 25 that are critical for them but those features that have little or no importance for them are omitted.
Archicad Start Edition 2022 is not available on all markets.
To purchase Archicad Start Edition 2022, contact your Archicad reseller.
Find information about the previous versions of Start Edition in this article.
The SE contains all the necessary tools to create a proper Building Information Model, with everything you need in the residential scale, like profiled or composite structures, priority-based junctions, the Shell tool, the Morph tool, and GDL objects.
Limitations:
- No Curtain Wall
- No Point Cloud data import and visualization
- No MEP Modeling
- No PARAM-O add-on
The complete 2D feature set of Archicad is part of the SE package: model-based documentation, 2D tools, layout books, etc. There are no limitations in this area.
Archicad Start Edition provides basic visualization techniques like real-time shaded 3D environment, a simple rendering engine (the so-called basic engine), 3D Styles, and the ability to save BIMx Hyper-models.
Limitations:
- No advanced (Cinerender) photorealistic rendering
- No Sketch rendering
Latest IFC, BCF, DWG, and DXF file exchange capabilities to enable full model-based and hybrid coordination workflow with consultants.
Limitations:
- No STL export
- No Rhino export/import
- No Grasshopper-Archicad
- No Solibri Connection
The Archicad Start Edition doesn’t contain any Teamwork feature because it’s intended for solo architects. It provides full control of IFC Preferences and Managing Classifications in IFC Import/Export.
Limitations:
- No Teamwork
- No Hotlinked Modules
- No XRefs
- Limited External Drawing support
- No Collision Detection
- No Structural Analytical Model workflow
- No 3D Model Compare
The main difference between Archicad Start Edition and Archicad Full version is productivity. You can do everything with the SE version, but you can work faster with the Full.
Limitations:
- No Renovation
- No Publisher
- No Revision Management
- No Link element height to stories
- No Import element property data from Excel
- No JSON-Python API for Archicad
- No Energy Evaluation
- No Physical Model Check
- No Export/Import Issues via PDF markup
The Archicad Start Edition 2022 is configured to manage small-scale projects with rapid software reaction, but it’s not ideal for large-scale projects.
Limitations:
- Multithreading capable algorithms use max 2 cores of the CPU
Check the new features comparison chart below to see the exact differences between Archicad 25 full version and Start Edition 2022.
New feature of Archicad 25 |
Type |
Included in SE2022 |
Workflow |
yes |
Modeling |
yes |
Modeling |
yes |
PARAM-O Improvements |
Add-On |
no |
Load Handling in Structural Analytical Model |
Open BIM |
no |
Automatic Export Mapping of Manufactured Profiles |
Open BIM |
no |
Custom Alignment of Replacement Profile (1D Members) |
Open BIM |
no |
New Offset Adjustments/2D Cutback Improvement |
Open BIM |
no |
Connection Range Improvements |
Open BIM |
no |
Support for All Released SAF Versions |
Open BIM |
no |
Create Structural Supports - Streamlined Input |
Open BIM |
no |
Workflow |
yes |
RFA and RVT Geometry Exchange |
Open BIM |
no |
Archicad - Solibri Connection |
Open BIM |
no |
Surface Textures on Sections/Elevations/Interior Elevations Viewpoints |
Visualization |
yes |
Visualization |
yes |
Modeling |
yes |
Modeling |
yes |
Track Changes and Model Compare improvements |
Workflow |
no |
Workflow |
yes |
Workflow |
yes |
Updated Surface and Fill Settings - Realistic soft shadow and cover fill option on top of textures |
Visualization |
yes |
Support for Rhino 6 and 7 |
Modeling |
no |
Export Building Material Classifications as IFC Classification References |
Collaboration |
yes |
Visualization |
yes |
Archicad Survey Point Supported in RVT Workflow |
Collaboration |
no |
Redshift by Maxon rendering engine – faster, GPU-based rendering |
Visualization |
no |
Documentation |
yes |
Label Zones with auto-text and/or GDL based Labels, just like other elements |
Documentation |
yes |
Schedules: control Merge Uniform Items per fields on a more granular level |
Documentation |
yes |
Workflow |
yes |
Workflow |
yes |
Option to hide contours in model views of Cut and Uncut parts of elements |
Workflow |
yes |
Update properties in hotlink modules |
Workflow |
no |
New command to check for the overlap of linear elements - Partial overlap check on linear elements: line, polyline, arc, wall, beam, column |
Workflow |
no |
Workflow |
yes |
Hardware and software requirements are modified from time to time. For up to date information on system requirements, please follow this link: www.graphisoft.com/support/system_requirements/
Archicad Start Edition 2022 will be able to open files that were created with:
Start Edition 2022 files can be opened with:
Saving projects files:
Files created in Archicad Start Edition 2022 can be saved as:
In the following steps, we take you through the process of installing the Archicad program at a stand-alone workstation. Archicad Start Edition is available by electronic delivery or on DVD, depending on your market. For details, contact your distributor.
Electronic Delivery
Download Archicad SE 2022 to your computer, then proceed with the installation.
Install from DVD
Insert the Archicad SE 2022 DVD into your computer’s DVD-ROM drive. To avoid performance issues, it is recommended that you first copy the installer from the DVD to your computer and install the program from there.
Macintosh users
1) Go into the “Mac” folder.
2) Copy the Archicad-Start-2022....dmg file to your computer.
3) Double-click the dmg file.
4) In the appearing volume, double-click the ArchicadInstaller.app to start the installation wizard.
Windows users
1) Go into the “Win” folder.
2) Copy the Archicad-Start-2022....exe file to your computer.
3) Double-click the exe file to start the installation wizard.
After that, follow the detailed installation instructions to install Archicad Start Edition 2022. If you encounter any problem during installation please check this page.
To uninstall Archicad Start Edition 2022 from Windows, it is best to use the “Programs” or “Add or Remove Programs” utility, accessible from the Control Panel.
You can also browse to your Archicad Start Edition 2022 folder and execute the uninstaller in the Uninstall.AC subfolder.
On a Mac, navigate to the “Uninstall.AC” folder in your Archicad Start Edition 2022 folder, and select the “Uninstall.app” application.
The Uninstall Wizard will remove files which were installed by the Archicad Installation Wizard. CodeMeter and associated components are not removed.
The uninstaller will not remove any files you have created in the Archicad main folder - e.g. Archicad project files that you saved into the Archicad main folder.
For Silent uninstall check the Install Guide.
When you start Archicad, the program automatically checks to see if you have a license available. If so, you are ready to work. To update, download and otherwise manage your license keys, use the License Manager Tool. The License Manager Tool is automatically installed to your computer as part of the installation of Start Edition. It is also available for download at:
www.graphisoft.com/downloads/licensing/
The Hardware Key (Dongle) contains your license information on a USB stick. Before you start using the latest version of Archicad Start Edition, this Hardware Key must be updated. For the update process, start the License Manager Tool (LMT) and follow the directions. See: https://help.graphisoft.com/lmt/. Now you are ready to use Start Edition 2022.
Note: After updating your license key to Archicad Start Edition 2022, you can still use all earlier Start Edition versions. (To run SE 2008 or SE 2009, you must have its latest hotfix installed.)
The Software Key is a software-based license. Using the License Manager Tool, a software key can be downloaded from the License Pool to a local client Computer. To download a software key, start the License ManagerTool (LMT) and follow the directions.See: https://help.graphisoft.com/lmt/.
If you are using a single license and plan to work on a different computer, you should upload the software ey to the License Pool, so that you can access it from a different location. (Internet connection is required.)
When you start Archicad, the program automatically checks to see if you have a license available. If you don’t have a license at all, you can continue in Demo Mode. Demo Mode gives you full functionality except file saving. Use Demo mode to open, view and try out functions.The unavailable commands and menu items are disabled, and the Archicad title bar changes to Archicad SE 2022 Demo. Your Archicad program may also be restricted to Demo mode for the following reasons:
In case of a lost or defective License Key, contact your local Archicad distributor.
If you already have Archicad Start Edition 2022 installed, and start the Installation Wizard, you are given two options:
1) Add will add new features to your current installation. You will see all available features in a list and you can check features to be added to your current installation.
2) Repair will reinstall Archicad Start Edition 2022 with the features of your current installation.
To check for available updates of your localized version of Archicad SE 2022 or Archicad SE 2022 libraries, start Archicad SE 2022 and do any of the following:
Note: If you have an updater patch installed and use the Add/Repair function of the Archicad SE 2022 Installer, you will be prompted to re-apply the updates after the modification or repair is carried out.
I'm looking for a total Comparison between Archicad 25 and STAR(T) Edition versions. Like there was for Archicad 24.
Does this help?
https://Graphisoft.com/de/Archicad/startedition-Archicad
Does Archicad Start Edition work with Twinmotion (Mac / Windows) or Enscape (for Windows)?
Is it the add on "DatasmithARCHICAD25Exporter.bundle" that is used for Twinmotion then?
