Getting started
Basics to start you off, plus new features and improvements
Articles
ABOUT THIS ARTICLE This article highlights selected new features and improvements in this version of Archicad. For the complete list of features, see the New Features Guide. For system requiremets, see System Requirements Learning Center – Digital OnboardingAI Assistant – Ar...
  • 41900 Views
  • 7 likes
  • 0 comments
The Archicad Project Compare is a free application that allows you to precisely compare Archicad projects during migration to a new Archicad version. With the Archicad Project Compare Add-On, project migrations become trackable, safe, and transparent by checking layout conte...
  • 34395 Views
  • 3 likes
  • 0 comments
Making version differentiation easier We understand that many of our users find it challenging to distinguish between different versions of Archicad and DDScad, especially when multiple versions are installed on the same desktop. To address this, we are excited to introduce ...
  • 18457 Views
  • 8 likes
  • 0 comments
On October 2, 2024, Graphisoft® released Archicad 28, the latest version of its award-winning BIM software. This article highlights some of the best new features and improvements implemented in this version of Archicad. For a full list of new features visit the New Features ...
  • 41877 Views
  • 2 likes
  • 0 comments
Graphisoft released Archicad 27.2.0 Update (5003, 5004) in all languages for both Full and Solo versions on 26th of March 2024. Read this article to learn what new features and functionality improvements are available in the update. There are minor differences between the Pr...
  • 8875 Views
  • 7 likes
  • 0 comments
We’ve packed some handy workflow improvements into Archicad 27. BIM Managers and lead architects are welcome to go on a quick tour with us to discover which features are in place to boost your productivity and effectiveness in Archicad. Distance GuidesExtended search capabil...
  • 13806 Views
  • 4 likes
  • 0 comments
Table of Content Your Best Design OptionDesignEnhanced Design Exploration with Design OptionsImproved Project Management – Enhancements to Attribute ManagementTool and Workflow ImprovementsModern GDL EditorVisualizeStreamlined VisualizationCollaborateStructural Workflow Enha...
  • 27927 Views
  • 4 likes
  • 0 comments
Table of Content Archicad Solo Compared to Archicad full versionTechnical InformationHardware and Software RequirementsFile compatibilityDownload and installUninstallingLicensing Based on Archicad's award-winning Building Information Modeling (BIM) technology, the feature-li...
  • 26161 Views
  • 3 likes
  • 0 comments
This article will cover solutions to known issues regarding the installation and start-up of Archicad 26. You'll find several specific and detailed issues that are independent of the version you have. You'll also find the reason why these problems might be happening and how ...
  • 21625 Views
  • 1 likes
  • 0 comments
Table of Content Project Location uses coordinate data only (no more Cities attribute)Get previews of Archicad updatesWhat is an update preview?BIMx related improvementsBIMx Hyper-model: control texture size for optimal visual quality and file sizeChange in BIMx 3D formatSim...
  • 11453 Views
  • 2 likes
  • 0 comments
Table of Content Stay focused, design moreArchicad keeps getting betterNew featuresDesignVisualizeCollaborateDocumentAdditional improvementsGet started with Archicad 26Before installingDownload and installLicense typesArchicad 26 User Guide Stay focused, design more Graphiso...
  • 55620 Views
  • 6 likes
  • 0 comments
In this article, we talk about a new feature which has been implemented within Archicad 26. Graphisoft releases Archicad regular updates every few months and if you have enabled the check for update option while you installed the software or in the Archicad work environment,...
  • 18564 Views
  • 6 likes
  • 0 comments
Table of Content 1. Line popup shows names in alphabetical order2. Updated Surface and Fill Settings3. Edit multiple Layer Combinations at once4. MEP Label5. Track Changes, Model Compare: Structure parameter6. Object Settings: Elevation and 3D preview can be rotated independ...
  • 6259 Views
  • 2 likes
  • 0 comments
Table of Content How do I access the update?Why should I update Archicad?What should I expect after updating Archicad?New Features1. Zones appear in section and elevation views and can be labelled2. New Graphic Override options3. More control over schedule format4. New handl...
  • 49170 Views
  • 19 likes
  • 0 comments
Stay in the loop!Visit our Roadmap for a clear view of our ongoing feature development. Go to Roadmap Archicad 29 Unlock AI-powered workflows, built-in MEP modeling, productivity enhancements, and advanced documentation to boost your BIM workflows and experience design innov...
  • 89487 Views
  • 13 likes
  • 0 comments
When working on complex BIM projects, it is essential to instantly identify, select and zoom-in elements on Floor Plan or in 3D views while working in Section, Elevation or Interior Elevation views. The new navigation commands help you to save time and reduce frustrations. T...
  • 6234 Views
  • 1 likes
  • 0 comments
Duke Ellington School of the ArtsArchitect: cox graae + spack architects | LBA Joint VenturePhoto © Chris Ambridge Graphisoft® has released Archicad 25, the latest version of its award-winning BIM software.Powerful enhancements to design, visualization, documentation, and co...
  • 24185 Views
  • 0 likes
  • 0 comments
Table of Content What's new in Archicad 24 Update 3?Create Custom Objects on Windows and macOSSave Time with the Improved Structural Analytical ModelList of Issues Solved in This UpdateAbout Previous Updates
  • 4489 Views
  • 0 likes
  • 0 comments
By releasing new features and enhancements with every Archicad update, our users will experience continuous improvement throughout the year. Read this article to learn what new features and functionality improvements are available in Archicad 24 Update 2 (build 4007) and lea...
  • 7178 Views
  • 0 likes
  • 0 comments
What is an update? In between two major releases of Archicad, GRAPHISOFT ships improvements and new functionality for the software in the form of updates. These are released regularly and are available through the Check for Updates notification system in Archicad. It is reco...
  • 7231 Views
  • 1 likes
  • 0 comments
Archicad 24 brings significant improvements, but in this article, we look at small differences that will make a higher quality user experience. 1 - Improved Transparency Depth Handling in 3D It is essential to have a sense of depth when in 3D. So we improved how semi-transpa...
  • 5735 Views
  • 0 likes
  • 0 comments
Archicad 24 Signature building creditsMERDEKA 118 | FENDER KATSALIDIS | fkaustralia.com GRAPHISOFT® has released Archicad 24, the latest version of their award-winning BIM software solution.Archicad 24 connects design and delivery teams in a fully ‘open’ BIMcloud environment...
  • 16142 Views
  • 1 likes
  • 0 comments
Do you need to energize before a deadline? You do not even have to quit Archicad to disconnect and have some fun. Here are some games, transformable objects and other stuff to discover. Lean back and enjoy the easter eggs you didn’t even know about. Here are the Easter Eggs,...
  • 44252 Views
  • 7 likes
  • 0 comments
Creating custom add-ons for ARCHICAD requires a solid knowledge of C and C++ as well as a willingness to learn through studying sample code, documentation, and header files. Be sure that you have read the "API White Paper" in the documentation to be sure that the API Develop...
  • 10113 Views
  • 0 likes
  • 0 comments
Labels
