on
2021-08-12
11:00 AM
- edited on
2026-06-30
04:47 PM
by
Emoke Csikos
Unlock AI-powered workflows, built-in MEP modeling, productivity enhancements, and advanced documentation to boost your BIM workflows and experience design innovation with Archicad 29.
Release year: 2025 |
Design the future with Archicad: design sustainable and better performing buildings with AI, work seamlessly with engineers, build momentum growing your business.
Release year: 2024 |
A brand-new design option solution, updated visualization tools, improved project management workflows, and open, multidisciplinary design collaboration make Archicad 27 your best design option.
Release year: 2023 |
New Cloud-based Software Licensing
Open BIM Workflow Improvements
With powerful improvements to automated design, documentation, and collaboration workflows, and professional out-of-the-box visualization solutions, Archicad 26 lets you focus on what you do best: design great buildings.
Enhanced Documentation and Modeling Capabilities for Kitchen Cabinets |
New Building Material Property Set for Life Cycle Assessment and Sustainability Calculations |
| Automatic Live Load Generation | Create a Copy When Stretching Circles | Easier Management of Graphic Override Combinations |
| Export Component-Level Data to IFC | Faster Export to FRILO | Improved PDF import |
| Improvements of the Level Dimension Tool | Improvements of Update 2 | Morphs Exported as IfcSpace |
| New Autotext Options for Master Layout and Subset Information | Opening Tool Surface Overrides | Renewed Additional Surface Catalog |
| Representation of MEP Element Slope Direction | SAF Translator Improvements | Support of Multi-Segmented Columns and Beams |
Powerful enhancements to design, visualization, documentation, and collaboration capabilities are a direct response to user feedback, making Archicad 25 the most user-driven version to date.
Release year: 2021 |
| Additional Improvements | Archicad - Solibri Connection Add-on | BIMx Large Model Support for Android Users |
| BIMx Web Viewer Technology Implemented in the Desktop Viewer | Expanded Design Freedom with Polygonal Openings | Export Building Material Classifications as IFC Classification References |
| Native RFA and RVT Exchange and Improvements | New Properties for More Accurate Component Lists | Improvements of Update2 |
| Structural Analytical Model Refinement |
Archicad 24 connects design and delivery teams in a fully ‘open’ BIMcloud environment, powered by advanced collaboration and communication workflows. Seamless and transparent information exchange builds trust among team members, eliminates model duplication and redundant work between architects and engineers.
Release year: 2020 |
| Automatic Structural Analytical Model Generation in Archicad | Archicad option set values available as a 'pull-down menu' when exported to Excel | BIMcloud as a Project Coordination Platform |
| Dark Mode Support on Mac | Desktop Viewer update | DGN v8 Support |
| IFC Structural Analysis Model Import/Export) | Improvements of Update 2 | Improvements of Update 3 |
| Integrated MEP Modeler | iOS application update | Issue Management in Archicad and Other Applications |
| JSON/Python API for Archicad | Managing Changes and Assuring Model Quality in Archicad | Hidden Gems |
| Unlimited 3D model size in BIMx | Representation of the Structural Analytical Model | Structural Analytical Model Exchange – SAF and IFC SAV |
| 2D Representation of Connected Slabs | Beam and Column Tool Renewal | Faster IFC Export and Import |
| Faster Switch between Tabs | Faster Rebuild of Views | Information Management (Custom Properties for Building Materials) |
| Integrated Software Key Activation and Deactivation | Interoperability | New Startup Dialog |
| Navigating among Tabs | New Opening Tool | Hidden Gems |
| Open Project Faster | Renamed View Settings No Longer "missing" | Visualization (New CineRender Engine, Surface Catalog Content and Delivery Update) |
| Store Only Visible Parts of Linked Content | Text Label Pointer Lines: More Options |
| Archicad– Grasshopper LIVE Connection | Curtain Wall Renewal | Custom Geometry Modifiers in Profiles |
| Expression Defined Property Values | Export of Component Quantities and Properties to IFC | Further Enhancements of Stair Tool and Railing Tool |
| Library Enhancements | Model View Options Dialogs | Hidden Gems |
| New CineRender Engine | Faster & smoother 2D navigation | Trackpad and Magic Mouse support |
| Updated Attribute Manager | Updated Curtain Wall – Graphical Custom Pattern Creation |
| Stairs and Railings | Collaboration Improvements | Full Control of IFC Preferences |
| Classification Management | Curtain Wall Editing Mode Renewal | Managing Classifications in IFC Import/Export |
| Hotlink IFC | Introduction of 3D Styles | BIMx Export Improvements |
| Archicad 21 Small Improvements | Publishing IFC | |
| Productivity Improvements | Collision Detection |
| 3DM Import-Export | CineRender Engine Upgrade: R16 | DWG Improvement |
| Graphic Overrides for Design Communication | Graphical Favorites | IFC Improvements |
| Improved Library Management | Improved Tab-Based Navigation | NURBS Definition in GDL |
| Refreshed User Interface | Two-Point Perspective | User-Defined Elements properties |
| Label Tool Enhancement | Library Improvements (Simplified Door/Window UI) | IFC Import Improvements |
| Improved Background Processing | Interactive Surface Painter | Optimized OpenGL Engine |
| New Guide Line System | PDF Improvements | Point Cloud support |
| BCF Compatibility for Expanded IFC‐Based Collaboration | BIMcloud Integration | DWG Developments |
| Enhanced Mark-Up Features | IFC Quality Improvements | Interior Elevation Improvements |
| Improved Revit 2015 Connection | Improved PDF-based data exchange | Labeling IFC |
| Labeling IFC Data | Library Improvements | New Integrated CineRender Engine |
| New Objects | New Lamps and Light Sources | Revision Management Improvements |
| Reservation and Feedback Changes in Teamwork |
| 3D Cutting Plane | Building Material | Core-Based Reference Line |
| Curved Beam | Energy Evaluation Improvements | Export to STL Format |
| Floor Plan-Based 3D Document | IFC Improvements | Integrated Connections with Google Earth and SketchUp |
| Model-Based Junctions | Link Element Height to Stories | PDF/A Support |
| Performance Improvements |
| Assign Thermal Properties to Archicad Fills | BIM Components Portal | Easier Library Part Access |
| Easy-to-Use Rotate Command | Expanded Teamwork Backup Options | Expanded Project Info Dialog |
| Graphical Editing | Improved IFC Collaboration | Integrated Energy Evaluation |
| Morph Tool | Transform Existing Elements | Quick Energy Evaluation Report |
| Smarter DXF/DWG Data Exchange |
| 3D editing plane | 3D Guide Lines | 64-bit Mac version |
| Complex Roofs | Customer Experience Improvement Program | Easy Library Migration |
| Enhanced Model Connections | Fast AutoSave | IFC properties as Archicad parameters |
| Renovation | Shell tool | Skylights |
| 64-bit BIM Server for MacOS | Expanded Find and Select criteria | Dimension prefix and suffix |
| New interaction in schedules and indexes | New offset functionality | Open Design Collaboration |
| Teamwork Travel Pack | Site-survey data import | Shadows in OpenGL |
| Streamlined export of schedules to Excel | Streamlined library migration and more details on conflicting or missing parts | Unlimited skins for composites |
| Annotated schedules | Certain library part parameters now in Model View Options | Control of section/elevation boundary (cut) lines |
| Embedded objects and libraries | Improved criteria (filters) for Find & Select and schedules | Improved DWG exchange |
| License borrowing (network license) | New TeamWork concept with BIM Server | Oriented view |
| Ruler, "fit in window" view setting | Roof/slab edge material control | Soft insulation |
| Slanted slab edge |
| 3D Document | Bi-directional drawing markers | Curtain Wall tool |
| Fill enhancements including image fills | Improved Hotlink management | Multithreading/multicore support |
| Multipage schedule layouts | Nudge/align/distribute elements | Partial structure display |
| Publish to PMK | Reveal options for doors/windows |
| Interior Elevation Tool | Multistory Hotlinked Modules | New Curved Wall Types |
| Linework Normalization | Link Construction Elements to Stories | Long File Names Allowed |
| Pen Sets in Views | PDF Export | Quantities of Individual Element Components |
| Section/Elevation Tools Separated | Single Undo Queue | Uncut Line Types |
| Virtual Trace | Worksheets | XREF Layer Separation |
| First version for Intel based Mac |
| AutoText | Creating custom components (e.g., door panels) | Customizable Work Environment |
| Distorted and gradient fills | Enhanced schedules and new project indexes | Element snap |
| Flexible placement of wall openings | Floor plan cut plane | Guidelines |
| Integrated layouting including Drawing Tool | LCF for libraries | Named Pen Sets |
| New menu structure | New 3D Orbit and Explore modes | Numeric input via Tracker |
| On-screen vs model view options | Placeable PDF | Pre-selection |
| Profile Editor | Project Organizer | Shaded sections/elevations |
| Slanted/Profiled elements | Story levels in sections/elevations | Tracker |
| View selected elements in 3D |
| Advanced Fill/Line Categories | Docking Palettes | Improved Pet Palettes |
| Independent Detail | Intelligent AutoSave | Library Part Search |
| LightWorks rendering engine | Line Weight | Parameter Transfer |
| Quick Selection | Rich Text | Section Transparency |
| Text Rotation | Work Environment Customization | XREF Dialog |
| Automatic Clean Intersections at Walls | Arrangement of Print Area | Editable Library Hotspots |
| Header/Footer Option for Print | Hyperlinks in PDF (Win) | Keyboard Shortcut Customization |
| Layout Book | Navigator | OpenGL |
| Print Marquee | Solid Element Operations | Support QuickTime Image Format |
| Wall End Tool | Window Background Plan |
| Construction Simulation | Element ID Manager | Favorites Palette |
| Freehand Spline Tool | Library Browsing Controls | Library Manager |
| Library Status Report | Mark-Up | Plot Setup |
| Quick Views in 3D | Publisher | Reviewer |
| Section Line Display | Skylights | Structural Grid |
| Wall Wizard | Zone Stamp Rotation |
| 3D Zones | Additional Special Snap Points | Beam Tool |
| Boolean | Circular Arcs in Dimensioning | Composites for Roofs |
| Custom Label Type | Creating Patches | Editing in 3D |
| Editing in 3D | Elevation and Gravity Control | Ellipse Generation |
| Explode | Extended Find&Select Options | Figure Tool |
| Ghost Story | Gravity and Hole Adjustment for Meshes | Hotlinked Modules |
| Magic Wand | Mesh Tool | More DXF/DWG Conversion Options |
| New Relative Construction Methods | New Snap Points | New Wall Types |
| Resize | Roof Generation and Trimming in 3D | Rotated Grid System |
| Round Columns | Symbol Hatch | Trimming Elements to Roof |
| Trimming at Intersections | Updating Zones | Vectorial Hatches and Sun Shadow in Sections/Elevations |
| 3D Textures | Column Tool | Editable Sections |
| Intelligent Cursor | New Software Development Kit | New Wall and Roof Construction Methods |
| QuickTime VR | Splines | Teamwork |
| Zone Tool |
| Camera Tool | Custom Axonometries | Extended Arc/Circle |
| First Windows version | First version to appear on both Mac and Window | Handling of Alpha Channel |
| Import Pictures | Label Tool | Lamp Tool |
| Line | Merge Projects | Mesh |
| PlotMaker improvements | Rendering | Sections/Elevations generated from Floor Plan |
| Smarter Text Editing | Window/Door |
| Colors |
| Integrated 2D and 3D module |
| Separate 2D and 3D module |
