3D navigation and disappearing objects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-07-18 02:57 PM
While navigating in 3D mode (Open GL Shading) most objects disappear. They re appear when I stop moving around making it very difficult to show the 3D space.
Any idea why this is happening?
Thanks!
- Labels:
Performance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-19 02:53 AM
If not then it is obviously an OpenGL problem.
What sort of video card do you have and have you tried updating the drivers for it?
Also what version of Archicad and operating system are you using?
It is a good idea to add this info to your profile signature as it can affect the answers you need.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-30 02:11 PM
Also check your 3D elements are not a very long way from the project origin (as in kilometers away) - things can get flakey when that happens.
Also ensure you don't have hugely polygon intensive objects in the current 3D navigation view - depending on the specs of your GPU, there may just be too many polygons to render these dynamically in OpenGL mode . You could try marqueeing around just the elements you are working with (then hit Ctrl F5) to reduce the load in 3D navigation.
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-30 02:57 PM
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-30 03:06 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-30 04:01 PM
If you are modelling at some XY coordinate related to the 'real world' for BIM export reasons, the better method is to use the special object that fixes this for exports.
I generally have my 0,0,0 as the cross between the bottom left grid lines of my model.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-30 05:21 PM
I am am interested in this 'special object' you mention for reconciling a need for distant real world origin. Can you elaborate?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-31 08:36 AM
There is also the PointCreator addon bit, that I believe does pretty much the same.
Edit: slightly related, you can also set up 'sea level' and 2 more reference levels (for which you can specify a custom name) in the Project Preferences, for those who might model things at some silly Z elevation for dimensioning. Say you are Dutch and your projects base level is a reasonable 2,3 m below sea level, just set the sea level at 2,3 m and you can dimension things at -2,3 m.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-08-04 03:23 PM
mantrajt wrote:
Hi:
Thanks!
There is an article on Help Center that may help you handle this situation:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-09-10 07:26 PM
M1 Macbook Pro
