Installation & update
AC 11 crashes when using stairmaker (and other objects)
Just installed AC11. I can place a stair object in the model, but if I try to move it, the program crashes - any ideas? I've already installed the latest patch...
Actually, it seems to crash whenever I try to manipulate any object... help!
rjwilden
Did you intall the hot fix with Archicad running. This would cause your problem.
Richard
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
Nope - I had to reinstall th eprogram, which was a pain, but it worked...!
I have noticed in the past on earlier versions of Archicad that if you try to adjust or change the library object using the task bar instead opening the object that in some cases this may cause a crash. I have not noticed that in A11 yet.
