2013-07-24 08:09 AM
2013-07-24 08:15 AM
2013-07-24 02:11 PM
2013-07-24 06:05 PM
ejrolon wrote:
Have not experienced slowness on Details.
Just guessing, are you placing Model Views in the Layouts or Saved Views?
If the former the slowness might be because AC has to process the layers as "Custom". This is just a guess.
2013-07-31 07:11 PM
Jonathan wrote:Jonathan,
Only "save view and place on layout" there are quite a few views on my plan layouts that update themselves if that is what you mean by model view. I'm thinking that this problem might be because I am using Vista ultimate 64 bit. Graphisoft says 17 will work with this OS, but
they recommend windows 7 or better. Already discovered that I can't make a bimx file of my project. Maybe this problem is just another indication that 17 needs the newer OS.
2013-07-31 07:32 PM
Marton wrote:Jonathan wrote:Jonathan,
generally Vista itself should be fine, we are not aware of any operating related slowness.
One idea that comes in my mind is whether you have trace reference turned on while working on the layout. Please check this, turn it off if it was on and let us know the results.
Marton
2013-07-31 07:42 PM
I could send you a pla if you have a large file service.
2013-07-31 08:05 PM
please get in touch with my colleagues in our US office and they will give you a link where you can upload the file. Also they will check it right away to find a solution for this.
Phone: +1 (800) 238-3992
Email: support at graphisoft.com
Thanks,
Marton
2013-12-20 09:44 AM
2013-12-20 10:18 AM
eszytvie wrote:Hi,
Hi!
Have you found a solution to this problem? Nothing I have tried so far works, it is extremely slow.
Please help!
Thanks
