ElberGalarga
ACCESS DENIED BETA PROGRAM ARCHICAD 30
Me llego un correo donde fui seleccionado para poder porbar la versión beta de archicad 30, sin embargo al ingresar con mi correo para el foro de descarga me aparece que mi acceso esta denegado. ¿Alguien sabe cómo puedo solucionar esto?
Translation, inserted by moderator (Please only post in English in the English Forum!):
I received an email saying I was to test the Archicad 30 beta version, but when I with my email for the download forum, it says my access is denied. Does anyone know how I can this?
1 Solution
James B
There seems to be an issue in the redirect part of the link provided, but again not for all users. Our team is still investigating though.
In the meantime, can I ask those who have received emails, to check under the "Building Together" menu of this community (ie above), and see if "Graphisoft Beta Program 2026" appears and correctly admits you in?
Otherwise, in the link that was sent out, try removing the UTM parameters of the link - and paste the remaining URL.
Thanks again for your patience, and apologies for the inconvenience.
James Badcock
Go to post
12 Replies 12
Toni Clar
Same problem
runxel
Same here.....
Patrick M
same. was just going to post about this...
hoping its just a timing thing... will be checking back later. Also, the Beta link in the forum > build together is still just the boiler plate splash page giving an overview of the program, no links, no threads...
Lee Hankins
My colleague is getting the same issue too.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Claudiu Serban
Same thing happened like 2 years ago. They first set up the beta platform and add the links and stuff a few days later.
Archicad 28/29, macOS 26
Patrick M
try again... I had to re-authenticate my GSID 2x from the link provided in the email
ElberGalarga
"I already found the error, first you must accept the invitation to the group, it is a different email from the two that come to you, it is in spam or spam, you have to enter with the same email that you registered. I use an incognito window for any cache issue or emails that are already for auto-filling. After that he already allowed me access"
-Por favor escribe en inglés-
Moderator translated.
Ya encontre el error, primero se debe de aceptar la invitacion al grupo, es un correo diferente a los dos que te llegan, esta en spam o correo no deseado, te tienes que ingresar con el mismo correo que te registraste. Yo utilice una ventana de incognito por cualquier tema de cache o correos que ya estan para autorrelleno. Despues de eso ya me permitio el acceso
James B
Hi All,
Thanks for reporting, and we are aware of the problem already (some users could access). We're working on a solution and will get back to you when we have more info.
James Badcock
James B
James Badcock
