2018-05-01 06:26 PM
2018-05-05 05:19 PM
2018-05-23 02:31 PM
2018-08-08 02:59 PM
2018-08-08 03:37 PM
2018-08-08 04:58 PM
sboydturner wrote:Thanks Scott - a reasonable suggestion, but in this case the problems are almost certainly software related, because they are not present under ArchiCAD 22, and were not present on ArchiCAD 21 prior to the windows 10 creators update. The blinking cursor disappearance began with ArchiCAD 21 release 6000 - was not preset with earlier versions (though other issues were improved by release 6000)
Paul,
You mention that you are working on a 42inch 4K display, what are the specs of this display and how are you connecting to your computer.
A large part of your issues could actually be that your connection (eg hdmi) cannot adequately deliver a 4K signal at more than 30Hz refresh rate and the monitor is having to interpolate the data it is missing. Your connection will need to be HDMI 1.4 or DisplayPort 1.2 to deliver an adequate signal for a reasonable 4K experience, you will need to purchase HDMI and DisplayPort cables that are certified to this standard as most cables are not.
I have no issues with ArchiCAD on Windows 10 scaled 125% on 4K displays. Biggest issue is having a graphics card that can drive all those pixels when I have 2 screens connected.
4K is still ‘bleeding edge’ technology and you really need to make sure all parts of your system are up to the task.
Edit: I have had a look at your system specs in your signature and your system is probably being very much pushed to drive 4K display you really need a Quadro P4000 8Gb or GTX1080 8Gb to drive those screens and you would also need a more modern processor so that the graphics cards are not bottlenecked by the processor.
Regards
Scott
2020-08-24 12:54 PM
2020-08-25 03:02 AM
2020-08-25 03:07 AM
Barry wrote:Thanks Barry - that is a good suggestion.
If the screen scaling (100%) isn't an option and you don't have a non-4k monitor you can use, is it an option to work in 22 and then save back to 21?
You don't have to migrate libraries (you can stay with 21 library).
