Installation & update
ArchiCAD-PlotMaker crash when quitting
Eduardo Bell
I have the folowing problem:
Every time I quit Archicad and Plotmaker they crash. The Bug report program is launched. This happens also when BG Archicad self quits.
I have sent the BG report to GS in Boston. They asked me to reset the wibu driver, which I did. The problem subsists, I hope to hear more from them soon. I have not lost any data yet during these occurences, all information is saved OK and all other behaviuor is normal. It happens with ALL files.
I have not reinstalled the program yet.
My HD is 70 GB and has about 30 GB left.
Any hints as to which may be the problem or a posible solution?
Any preferences files to toss away safely might help?
Could it be conflicting with the active Virex (protection) or other software?
Thanks
Ed
USA v4.55 to v29) OS Sonoma v 14.6.1
MacBookPro 8-Core Intel i9 16GB ram
AMD Radeon Pro 5500M 4GB vram
Perpetual License Subscriber & Cloud Subscriber
12 REPLIES 12
Link
Have you tried deleting your preference (.prf) files?
Link.
Eduardo Bell
Hi Link, I only deleted the Bug Report preferences to no avail ( I did not restart the computer after doing it though).
I'm on a Mac, the preferences files have a .prefs extension. There are some .prf files in Archicad as well, I've got (3) FavoriteDefs.prf files and two RCC Favorites.prf files. Did you mean these?
Do you know if which ones I should delete?
Could you be more specific please?
Thanks
Ed
1. Close ArchiCAD and all other running applications.
2. (notice: the word "clear" in the next few commands, mean that the user may back up these files to the desktop via a Copy)
3. Clear pref's:
MAC (2 locations)
Macintosh HD: Users: <USERNAME>: Library : Preferences : Graphisoft : AC 8.1.0 v2 (or AC 9.0.0 USA v1)
Macintosh HD: Users: <USERNAME>: Library : Preferences : Graphisoft : PM 3.1.0 v2 (or PM 9.0.0 USA v1)
WIN (2 locations)
C:\Documents and Settings\<USERNAME>\Application Data\Graphisoft\ArchiCAD 8.1.0 USA R1 (or ArchiCAD 9.0.0 USA R1)
(and)
C:\Documents and Settings\<USERNAME>\Application Data\Graphisoft\PlotMaker 3.1.0 USA R1 (or PlotMaker 9.0.0 USA R1)
4.) Clear cache's:
MAC (2 locations)
Macintosh HD: Users: <USERNAME>: Library : Caches : Graphisoft : ArchiCAD Cache Folder : AC 8.1.0 v1 (or AC 9.0.0 USA v1)
Macintosh HD: Users: <USERNAME>: Library : Caches : Graphisoft : PlotMaker Cache Folder : PM 3.1.0 v1 (or PM 9.0.0 USA v1)
WIN cache locations (4 locations)
C:\Documents and Settings\<USERNAME>\Local Settings\Application Data\Graphisoft\ArchiCAD Cache Folder\ArchiCAD 8.1.0 USA R2 (or ArchiCAD 9.0.0 USA R1)
C:\Documents and Settings\<USERNAME>\Local Settings\Application Data\Graphisoft\PlotMaker Cache Folder\ArchiCAD 8.1.0 USA R2 (or ArchiCAD 9.0.0 USA R1)
- Clear the local Cache:
C:\Documents and Settings\<USERNAME>\Local Settings\Temp
- Clear the Windows cache:
C:\WINDOWS\Temp
5.) Start ArchiCAD/PlotMaker and see how your file now behaves.
Woody
Eduardo Bell
Hi Woody,
Unfortunately following the preferences/cache instructions you sent did not fix the problem, still crashing.
I wasn't sure what you meant by "Copy" to the desktop. I just dragged the folders to the desktop and restarted the programs. New folders were created which I replaced back with the old ones since the problem was not fixed.
Any idea what should be done next?
If I need to reinstall the software, do you know if it is OK to save my personal WE settings and add them to the newly created folders?
Thanks
Ed
I'll have to think about that. Just on a lark I might upgrade to 10.3.7
I can't see any reason why that would cause a problem.
Woody
TDabney
I have experienced similiar issues w/8.1 (not yet in 9.0). AC would crash at quitting - but not every time. I too, lost no data (yet). It seemed to happen when I was moving too quickly - doing a hard save and then hitting CMD-Q to quit before the save had finished. If I was more patient and waited until the save was done (count to 5 s l o w l y) I had better results. I would also get crashes if AC asked to save changes after quitting. It seems that when you're moving along too quickly, and you start another command before AC finishes the one it's working on - sometimes zooming around too fast and starting another command before the redraw is finished gets me - it gets confused and crashes. I've had better luck w/9.
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
Eduardo Bell
Yes, moving fast and being impatient does seem have a negative effect. I have been stopped short doing those hasty moves.
I have also been overloading the capacity of the machine by running too many applications at the same time.
So I've removed all the aforementioned files, uninstalled the software and made a clean install, all lead to the same result. AC/PM/BGAC all crash after quitting. They don't crash however if I make them 'Force Quit'
For those of you who may see a problem in it, here's a partial transcript of the Apple crash report on a clean install of Archicad but without the GS Bug Report software:
Date/Time: 2005-01-25 14:29:27 -0300
OS Version: 10.3.7 (Build 7S215)
Report Version: 2
Command: ArchiCAD 2
Path: /Applications/Graphisoft/AC9b/ArchiCAD 2
Version: ??? (???)
PID: 740
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x08e65000
Thread 0 Crashed:
0 <<00000000>> 0xffff8bc8 __memcpy + 0x428
1 ...ple.CoreServices.CarbonCore 0x902ca488 AddNewRef + 0xac
2 ...ple.CoreServices.CarbonCore 0x902c28e0 AddResourceCommon + 0xac
3 ArchiCAD 0x0217699c 0x2008000 + 0x16e99c
4 ArchiCAD 0x02176f04 0x2008000 + 0x16ef04
5 ArchiCAD 0x02180fa0 0x2008000 + 0x178fa0
6 ArchiCAD 0x02934078 0x2008000 + 0x92c078
7 ArchiCAD 0x02e0fd68 0x2008000 + 0xe07d68
8 GSRootLib 0x004d0df0 0x444000 + 0x8cdf0
9 ArchiCAD 0x030c7790 0x2008000 + 0x10bf790
There's more...
Ed
we've had this problem crop up on a few different machines -all G5's to date. Deleting preferences and caches fixed the problem. I'm narrowing down which one(s) are the problems and will send to GS.
Remember to export your work environment to the server or someplace else to save all your menu positions and key shortcuts. Then deleting the folders isn't such a problem.
will report any further news.
HTH
Wes
aahatimo
just had the same ac9 crash on quit w/ the 1965 build.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
