Archicad 20 Mac problem (1/4 blank & complete freezing)
hello,
i have archicad 20 on mac, all recent updates are installed
two problems -
1st - 1/4 of work window is empty (white), on every projection
2nd - randomly freezes computer, so even touchpad is blocked. have to choke my computer to death and and turn on again, what makes any progress impossible.
i reinstalled program, same problem
was looking through topics, couldn't find any answer. worked with archicad for 4 years, never had anything similar to that.
if someone have faced with this problem, please share your solution
10 REPLIES 10
Your version of MacOs matters, not just the updates to 20...
It seems that this is what you have run into:
http://helpcenter.graphisoft.com/technotes/operating-systems/mac-os-x-10-12-sierra/crash-freeze-disp...
Is this an issue with a specific file or does it occur on all files?
Does it also occur if you do a New & Reset in ARCHICAD and start you Project based on the default template file?
Could this be a graphic card driver problem? Have you recently updates you graphics card driver? If yes, can you try to revert back to an earlier version? If no, can you try to update the driver?
I think the Karl solution worked for kostya as it worked for me!! 😉
when archicad or apple, whatever it is, will fix this problem? I had been waiting the new update for a while.
It's too bad that Apple has not released a fix for this yet. I think, though, that they typically update graphics drivers only in 'point' updates to MacOS... and the 4th beta of 10.12.5 was released to testers just 4 days ago... I've not seen anything to say when 10.12.5 will be ready for the public...or if it will contain the needed fix:
https://9to5mac.com/2017/04/24/macos-10-12-5-beta-4/
If Graphisoft is testing 10.12.5, it would be nice if they let everyone here know if it will fix the issue or not...
Crashed 5 times today. dumped cache cleaned system, restarted. followed the directions to turn off 2d acceleration and 3d anti-aliasing. Still no effect.
Hope this get fixed soon by Apple !!!!!
Ruben V
Thanks for the info - some of my students had the same issue... Let's hope it will be fixed soon!
(òÓ,)_\,,/
www.studiov2.be
Archicad 26/27 + Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
Katalin Borszeki
Hi All,
This issue occurs due to latest MacOS update (10.12.4) which contains a faulty Intel Graphics driver.
GRAPHISOFT has reported this issue to Apple and asked for an immediate correction. Apple is in the process of investigating this issue.
Fpr further reference, please read the helpcenter article about it:
best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
KatalinBorszeki wrote:
Hi All,
best, k
So, I have a similar, but more extreme case perhaps.
Mac OSX 10.12.6
AC 20.0.0 v1 USA (5025)
One month new model MacBookPro, running 16 gigs RAM and this AC20 Build for a month, without issue. Updated to OS X 10.12.6 a week ago, and no issues running AC 20 as before.
However, today:
Working on the same 320MB file in the 2D and 3D window. Zoom tool fails and all we see are many repeated lines. Quit app and restart. Same failure appears. Quit app, then shut down the Mac. Restart. Complete system failure, the machine will no longer boot up, even in safe mode.
Any help greatly appreciated!
bruce
bdb/a
