2023-10-17 11:53 PM
So I have 2.5 MAJOR issues with 27...
Can anyone verify?
2023-10-18 04:59 AM
I had the first issue, even when starting a blank file - the startup screen was stuck for quite a while. I have a feeling it has something to do with the underlying new licensing method. I didn't bother to check however as I don't actively using it
BIM Manager - DKO Architecture - Archicad 28 on Windows 11
2023-10-18 08:33 AM
No such issue on my mac- other issues but not those....
2023-10-19 03:46 AM
Yes with an older machine it can definitely take that amount of time for a project to load.
2023-12-11 04:00 PM
I have two laptops, one older one brand new. I have issues opening up files in 27 at the start menu. They all hang, and I have to do a forced shutdown. I can only access them by going through the "browse for file". Then the screen shuts down, I wait, and the file opens.
2023-12-11 06:53 PM
No problem so far. Files are loading and publishing as expected.
One idea is to check whether an addon is causing this lag.
