Installation & update
Archicad 27 Issues
vfrontiers
So I have 2.5 MAJOR issues with 27...
  1. Files take an inordinate amount of time to open!  like 7 to 10 minutes!  Just a PLN... not tw'd
  2. Just tried my first PUBLISH...
    1. Seemed to cycle all the way down to the bottom of the list but got stuck on the last item...
    2. I went to the folder location where it was saving and watched it spike to 2.5GB pdf file and still growing when I force quit...
Can anyone verify?
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
5 REPLIES 5
MinhNguyen
I had the first issue, even when starting a blank file - the startup screen was stuck for quite a while. I have a feeling it has something to do with the underlying new licensing method. I didn't bother to check however as I don't actively using it
BIM Manager
DKO Architecture - HCMC
Robby
No such issue on my mac- other issues but not those....
Rob Marelli
AC 28.1
MacBook Pro (2023) M3 Max -48 Gb RAM - Sequoia 15.3.2
mthd
Yes with an older machine it can definitely take that amount of time for a project to load.
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Certificate IV Architectural & Building
Technology, (Estimation & Administration).
PLMARCHITECT
I have two laptops, one older one brand new.  I have issues opening up files in 27 at the start menu.  They all hang, and I have to do a forced shutdown. I can only access them by going through the "browse for file".  Then the screen shuts down, I wait, and the file opens.
Botonis
Mentor
No problem so far. Files are loading and publishing as expected.
One idea is to check whether an addon is causing this lag.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
