Installation & update
Archicad 28 build 4000 28.1.0 Preview crashing
calroc11
I recently updated Archicad 28 with the latest build, since then archicad has been constantly crashing...Anyone facing a similar issue.
I tried working on 3 different projects and facing the same issue, not sure what the solution is unless there is a new update...
let me know.
Caleb
Operating system used: Windows 4000
2 ACCEPTED SOLUTIONS
HK ARCHITECTURE
I've been having the same issue since I installed this update. Basically, the crashes happen randomly, sometimes after 20/30 minutes working, sometimes 20 seconds after opening the file. It seems that most of the time this happens when I use a keyboard shortcut to rotate ou move something on a 2D plan (object, wall, etc.), but it's still pretty random.
Yesterday I uninstalled Archicad 28 and reinstalled it with the 28.0.3 update. It seems to have solved the problem.
FYI, the file I've been working with was created and developed on the problematic 28.1.0 update,  so there seems not to be a problem with compatibilty.
Hope that helps.
HK ARCHITECTURE - Kévin PAIVA (France / Portugal)
Archicad 27
Windows 11 / I9 13900KF / RTX 3090 / 64GB RAM DDR4 / UltraWide Monitor
Tamas Gaspar
Dear All,
Thank you @calroc11 for the bug ID, it is also the DEF-23306. We investigated the case further, and indeed, the Distance  Guides are the reason behind it. Thanks for @Eduardo Rolon and @insideru for the workaround.
The development has identified the issue and working hard on this case. I will get back to you with more info about it in the final version of AC28.1.0. Until that, if you are on the AC28.1.0 Preview (build 4000), please disable Distance Guides to prevent the crash.
Regards,
Tamás
Tamás Gáspár
Manager, Partner Technical Support, Graphisoft
19 REPLIES 19
MitchD
Yep, updated one of my machines and experienced repeated crashes as well. rolled back to 28.0.3 for now.
Make sure you send in the bugs, keep note of the bug number and follow it up with your local support.
Very important to do this.
Srinivas
Yep, same issue on 3 of our PC's and on various projects.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
i tried repairing the file, but still the same, i plan to roll back, just wondering if it would not cause issues opening files in the previous update...any backward compatibility issues...
It shouldn't be a problem as a 28 file should be fine in any update version of 28.
But if the new update is crashing then you won't have saved in the updated version anyway.
Hi Barry,
If i decide to revert back to the old update 28.0.3, whats the steps to rollback to the old update? do i need to reinstall the hotfix or the entire software ?
can you please share some insights ?
HK ARCHITECTURE
Hope that helps.
Archicad 27
This is the same issue i have been facing for coupe of my projects, when i use the keyboard shortcuts or in the 3D view the software crashes...
Tamas Gaspar
Dear everyone,
Thank you for reporting the crash issues with AC28.1.0 Preview. @HK ARCHITECTURE, thanks for letting us know the workaround, it is a big help.
In order to investigate the issue, our development will need the Bug Report IDs. Please send in the bug report after the crash, and publish, here the ID that you receive. We'll check them and get back to you.
Thank you for the cooperation and also for the patience with this matter!
Regards,
Tamás
Tamás Gáspár
Setup info provided by author
