Josh Verran
CinerenderNEM: Application error
A colleague has had the below error message pop up despite not performing any rendering actions.
My understanding is they were just navigating a plan view or layout and the message popped up.
Hardly any of us use the rendering function either, if that assists troubleshooting.
I found a similar post below, but it appears unresolved, but also not able to be replied to.
https://community.graphisoft.com/t5/Installation-update/CineranderNEM-Application-Error-cinerender-c...
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
6 Replies 6
I might be stating the obvious, but have you looked in the 'BugReport.txt' file to see if there is any useful information?
Or maybe send this file to your local Archicad support people to see if they can tell you anything about it.
Josh Verran
Thanks @Barry Kelly
That's a more than fair question, and one that I must guiltily confess to not doing.
I was a headline reader.
I'll check out the content and see what I can find.
Yes, curious what the txt file contains.  Same issue reported 4 years ago in a VectorWorks forum... cause there was overclocking RAM of all things:
https://forum.vectorworks.net/index.php?/topic/67871-cinerendernem-application-error/
Josh Verran
If it's of interest, below is an extract.
I read something that indicated that the suffix "NV" might suggest an issue with NVIDIA.
Other than the message itself there doesn't appear to be any effects.
Critical_Log
[06:55:32] CRITICAL: glUniform1i64NV missing [ogl_context.cpp(3212)]
[06:55:32] CRITICAL: glUniform2i64NV missing [ogl_context.cpp(3213)]
[06:55:32] CRITICAL: glUniform3i64NV missing [ogl_context.cpp(3214)]
[06:55:32] CRITICAL: glUniform4i64NV missing [ogl_context.cpp(3215)]
[06:55:32] CRITICAL: glUniform1i64vNV missing [ogl_context.cpp(3216)]
[06:55:32] CRITICAL: glUniform2i64vNV missing [ogl_context.cpp(3217)]
[06:55:32] CRITICAL: glUniform3i64vNV missing [ogl_context.cpp(3218)]
[06:55:32] CRITICAL: glUniform4i64vNV missing [ogl_context.cpp(3219)]
[06:55:32] CRITICAL: glUniform1ui64NV missing [ogl_context.cpp(3220)]
[06:55:32] CRITICAL: glUniform2ui64NV missing [ogl_context.cpp(3221)]
[06:55:32] CRITICAL: glUniform3ui64NV missing [ogl_context.cpp(3222)]
[06:55:32] CRITICAL: glUniform4ui64NV missing [ogl_context.cpp(3223)]
[06:55:32] CRITICAL: glUniform1ui64vNV missing [ogl_context.cpp(3224)]
[06:55:32] CRITICAL: glUniform2ui64vNV missing [ogl_context.cpp(3225)]
[06:55:32] CRITICAL: glUniform3ui64vNV missing [ogl_context.cpp(3226)]
[06:55:32] CRITICAL: glUniform4ui64vNV missing [ogl_context.cpp(3227)]
[06:55:32] CRITICAL: glGetUniformi64vNV missing [ogl_context.cpp(3228)]
[06:55:32] CRITICAL: glGetUniformui64vNV missing [ogl_context.cpp(3229)]
Lingwisyer
Guru
OpenGL shader issue? Try updating your OpenGL driver?
MinhNguyen
My guess here is that the Cinerender process silently crashed. When you start Archicad, you may find an additional process called Cineware.exe running in the list of processes in Task Manager. If this process failed to launch for whatever reason upon starting Archicad, a similar error will appear. It's hard to tell exactly what could have caused this, so I suggest contacting local support with details for further investigation. But if your colleague never uses Cinerender, it will not affect Archicad much. Cineware/Cinerender is needed only if you use anything utilizing Cinerender engine (launching a render with Cinerender/check building material settings in Cinerender mode, etc...). Normal 3D navigation should not be affected
BIM Manager - DKO Architecture - Archicad 28 on Windows 11
