2025-03-05
		11:45 PM
		2025-03-06
		06:17 PM
I'm getting this warning after updating to Sequoia 15.3.1. Please help. I've tried delating the libosmesa.dylib file. Any other suggestions please.
Thank you
Operating system used: Mac Intel-based Sequoia
Solved! Go to Solution.
2025-03-06 02:54 AM
Thank you for the update. If Antivirus is not in use it won't be necessary to add the folder as an exception. Instead I would also suggest to make sure add Archicad 27 is added to 'Full Disk Access' on your device:
Click the “+” button to add a new application.
Navigate to Applications > GRAPHISOFT > Archicad (your version)
Select Archicad.app and click Open.
4. Restart Archicad: Close and restart Archicad for the changes to take effect.
There may be something blocking the Cineware components from being accessed.
THIS IS HOW I FIXED THIS PROBLEM. THANK YOU FOR YOUR HELP BARRY!
2025-03-06 12:35 AM
Not sure if its related to the same issue, but now I have an object that has disappeared from 3D.
2025-03-06 01:49 AM
Does this help at all?
2025-03-06 02:00 AM
Hi Barry,
Thank you for your help. I've tried deleting the file and it hasn't worked. Do you think i need to delete and reinstalling the program would help?
2025-03-06 02:05 AM
Maybe this is the solution?
https://community.graphisoft.com/t5/Visualization/Cineware-renderer-quits-in-ArchiCAD-28/m-p/635438
2025-03-06 02:13 AM
Thanks Barry,
Should I just delete the existing cineware folder and add the new one or do i need to reinstall?
2025-03-06 02:18 AM
I have never had to do it, but it should just be a case of delete and replace that folder.
2025-03-06 02:27 AM
I replaced it and reopened my file and the same warning is coming up. I might try to reinstall the program.
2025-03-06 02:29 AM
Restart the machine first.
Re-installing will just re-create the bad Cinerender folder if that is the problem.
2025-03-06 02:54 AM
