yesterday
I'm getting this warning after updating to Sequoia 15.3.1. Please help. I've tried delating the libosmesa.dylib file. Any other suggestions please.
Thank you
Operating system used: Mac Intel-based Sequoia
Solved! Go to Solution.
11 hours ago
Thank you for the update. If Antivirus is not in use it won't be necessary to add the folder as an exception. Instead I would also suggest to make sure add Archicad 27 is added to 'Full Disk Access' on your device:
Click the “+” button to add a new application.
Navigate to Applications > GRAPHISOFT > Archicad (your version)
Select Archicad.app and click Open.
4. Restart Archicad: Close and restart Archicad for the changes to take effect.
There may be something blocking the Cineware components from being accessed.
THIS IS HOW I FIXED THIS PROBLEM. THANK YOU FOR YOUR HELP BARRY!
14 hours ago
Not sure if its related to the same issue, but now I have an object that has disappeared from 3D.
13 hours ago
Does this help at all?
12 hours ago
Hi Barry,
Thank you for your help. I've tried deleting the file and it hasn't worked. Do you think i need to delete and reinstalling the program would help?
12 hours ago
Maybe this is the solution?
https://community.graphisoft.com/t5/Visualization/Cineware-renderer-quits-in-ArchiCAD-28/m-p/635438
12 hours ago
Thanks Barry,
Should I just delete the existing cineware folder and add the new one or do i need to reinstall?
12 hours ago
I have never had to do it, but it should just be a case of delete and replace that folder.
12 hours ago
I replaced it and reopened my file and the same warning is coming up. I might try to reinstall the program.
12 hours ago
Restart the machine first.
Re-installing will just re-create the bad Cinerender folder if that is the problem.
11 hours ago
