KarenD
Converting AC26 Intel files to Apple Silicon?
I have had my new MacBook pro since mid-February, but just learned today when I went to update that I should have been using the Apple Silicon version of AC26....So I have downloaded that, did the most recent update, but when I open any of my files, none of the windows and doors are showing up.  I get the little circle that means it's missing.  Do I need to do some kind of conversion process?  This is less than ideal.  Even opening old versions, the program just automatically updated libraries.
2 Replies 2
Sounds like you just need to reset the library path to the new ArchiCAD 26 ARM folder's library. No need for "file" conversion.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
KarenD
I found out that I had mistakenly downloaded the International version of AC26, so downloading the correct US version did the trick. Thank you.
